Need help with trailer please
Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By Toyanvil
Thread: Need help with trailer please
    Senior Member Holdnon72's Avatar
    Jan 2014
    New Jersey
    592
    Bought a 1998 Loadrite trailer. Its a straight spindle no brakes
    I took the hubs off to inspect bearings and races
    All looks good accept I noticed it had no flat washers on either side behind the crown nut
    Back of crown nuts have some light scoring wear bearings have rubbed
    But bearings have no wear on the outside cage surface
    Do I have to have a flat washer behind each crown nut?
    Without having the washers I have about 3 full threads on axle showing with nut and cotter pin in place
    Thanks for any info
    2013 TW200 Ims super stock pegs,zeta pro bend xc hand-guards,manrack,zeta muffs,Gerbing ultra light heated gloves
    May 2013
    Groton, NY
    2,663
    I don't know about yours, but mine has a key way in the axle that a keyed washer goes on between the nut and bearing. The washer is keyed to keep it from spinning if the bearing happens to spin. Some don't have the keyed washer, just a plain washer. If your axle doesn't have a key way, a flat washer should work fine.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Jan 2014
    New Jersey
    592
    No key way on mine
    May 2013
    Groton, NY
    2,663
    I just did a quick search on trailer axles, here is a picture of a "keyless" axle and it shows a plain washer with it. LINK Any flat washer that fits well will be OK. But if you never put a washer in I don't think it would cause any problems either. If a flat washer spins, it will also spin against the nut.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Yes, you should have a washer. Any flat washer that fits will NOT be okay. Use a Grade 5 or Grade 8 flat washer, grease flats lightly at install. Cheap Grade 2 washers are soft and will grind away quickly, contaminating the grease and ruining the bearings. Unless you have a real oddball bearing and hub set you can find replacements with tabs (if you have a groove) for just a couple dollars at any Northern Tool, Tractor Supply, or Rural King. Don't be too cheap or too lazy to do such a simple job right.
    Bearings are very hard, they WILL wear the nuts. Worn bits contaminate the grease and contribute to bearing wear. Correct washers provide a smoother surface than the bottom of the nut and a wider contact area that reduces pressure and thus reduces wear.
    May 2013
    Groton, NY
    2,663
    If the bearings are adjusted properly, the inner race of the bearing shouldn't be spinning on the shaft.
    2013 Yamaha TW200
    1996 Yamaha TW200
    Senior Member Toyanvil's Avatar
    Sep 2012
    Bakersfield CA
    234
    This plus 1
    Dubzha likes this.
    09 TW200
    04 BMW 1150GS
    61 Sunbeam Alpine
    May 2013
    Groton, NY
    2,663
    If I were you, I'd go with the majority here. Here is a link for trailer axle parts. Link
    2013 Yamaha TW200
    1996 Yamaha TW200
    May 2013
    Groton, NY
    2,663
    I did a search to back up my opinion, couldn't find one, so I'm eating a little humble pie right now. Here is a pro washer view point. Link
    2013 Yamaha TW200
    1996 Yamaha TW200
    Quote Originally Posted by scotti158 View Post
    Shouldn't, but often do rotate a tiny bit. If they are loose, take a black Sharpie to the spindle, let dry between layers. Tightens things up a bit. If they are tight, set bearings on a warm to the touch surface or in a barely warm oven to thermally expand a bit and they will slip right on, and when they cool they will be a tight fit.
    Outer races should never move in the hub. It usually takes a driver to get them out, but some folks make do with a brass drift. If you don't have the proper driver to replace them, or even if you do, put the outer races in the freezer for an hour and they will drop right in, then expand as they warm up to a snug fit.
  1. No wheeled trailer?
    By zardoz in forum General Discussion
    Last Post: 10-22-2012, 11:41 AM
  2. What do you think of this for a T-dub trailer?
    Last Post: 09-28-2012, 01:03 PM
  3. Trailer
    By CaribbeanTW in forum TW200 Classifieds
    Last Post: 07-06-2012, 10:51 AM
  4. Did someone ask about a TRAILER?
    By Batman1USA in forum General Discussion
    Last Post: 05-10-2012, 10:30 AM
  5. trailer tow behind TW
    By Caribbean in forum Performance and Customization
    Last Post: 02-12-2012, 12:44 AM
