Handlebar Vibration
Results 1 to 10 of 15
    Member OakCliffThumper's Avatar
    Dallas, TX
    72
    Just before the old forum went offline, there was a thread about a handlebar vibration dampening product. I looked a lot like a Tusk Riser, but seemed to have some type of red rubber that went between the riser and the bike.
    Does anyone remember what that product is and have any input on how well it works?
    Senior Member betopimienta's Avatar
    Texas
    158
    Quote Originally Posted by OakCliffThumper View Post
    Yes i remember that post also. Am tired of feeling tingly after long rides.
    I think it was this product. GRIP N RIP
    Texas
    158
    Quote Originally Posted by betopimienta View Post
    This was the the old post :
    07-11-2010, 5:25 PM
    crackpottery is not online. Last active: 5/27/2010 7:31:21 PM crackpottery
    Top 500 Posts
    Joined on 12-20-2008
    Posts 88
    Grip-n-Rip anti vibe riser
    Attachment: gripnrip.jpg
    Reply Quote
    just installed this. $150 -15% discount 34mm bolt pattern for 7/8 bars. Limits vibration quite a bit, easy to install.
    Report
    Member Black Hawk's Avatar
    Black Hills SD Yuma AZ
    32
    If you would like to try a cheep way that works,
    pull the clutch side grip off, lay the bike on its right
    side, and pour about 3000 BB in the handle bar, put grip back
    on and ride it and see if the vibration is gone.
    Summer in the Black Hills of SD
    Winter in the desert around Yuma AZ
    2004 TW
    2003 KLR650
    Senior Member HenryJ's Avatar
    Oregon, USA
    184
    Quote Originally Posted by Black Hawk View Post
    pull the clutch side grip off lay the bike on its right
    side and pour about 3000 BB in the handle bar put grip back
    I went with aluminum ATV high bars and filled them with lead shot. Worked great.
    "Speed doesn't kill, suddenly becoming stationary does." - Richard Hammond
    "Speed is just a matter of Money - How fast do YOU want to go?"-Mechanic from Mad Max-
    If at first you don't succeed - Don't take up Skydiving!
    - Hidden Content
    Dallas, TX
    72
    I've heard about the BB trick, but wasn't sure it would work. As cheap goes, it's worth a try.
    What about BBs vs. lead shot? Is one material better than the other?
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    seems like an expensive band-aid to me.
    the stock bars are the problem. for less than half the price of those risers, you could get a set of pro-taper aluminum bars, which fixed my vibration issues.
    Dallas, TX
    72
    Wheelie, is this the set of handlebars you bought?
    Pro Taper ATV Bars
    Austin, TX
    204
    Yes, I got the ATV Hi bars.
    I am only 5'8", but I really love the extra height. It really gave the bike a more comfortable position for me. It's a little more work for the ATV Hi bars to be installed though. I had to reroute most of the cables. I had a post about it on the old forum, but the search engine over there is being a butthole right now.
    I will add a few of the pics here.
    In this pic, you can see the cables that I rerouted. They were next to the ignition on the right side and I had to move them over into the other hole. This required the tank and seat to be removed so that I could unfasten some electrical connections to move the wires. On the left side, I had to undo the clutch cable to reroute it. It's not difficult work at all, but did require some time and effort.
    Next are a few pictures in the differences between the ATV Hi bars and the stock bars:
    It was totally worth the effort, but it is some added effort to go with the Hi bars.
    one other thing to note, the two holes you see on the right side of the stock bars are not there already on the pro-taper bars. they are aluminum bars, so it's simple to put some holes in there, but the job does require a drill and drill bit (can't remember what size i used).
    Member underthewheel's Avatar
    30
    yes the bb trick dose work, iv seened it quite a few time over the year.the ferst time i see it was a frend of mind at one of these honda shop i used to werk at in colege, and i thot its crazy until i go out four a ride on it.these is called v twins tingle, as most v twin give you the tingle in hands too youre sholder.the tw has the v twin tingles but without big moter four sure.i hasnt done it too mind yet but it on the list.fourget spending the outrages money on fancey handlebar,pull you grip off and fill weth bbs and put you grip back on.
    later on,
    fontintown firmarshel,
    tenny
  1. Handlebar
    By Havoc in forum Performance and Customization
    Last Post: 04-23-2012, 08:39 AM
  2. Handlebar switches
    By Tee Dubbs in forum Performance and Customization
    Last Post: 09-30-2011, 05:04 PM
  3. Handlebar Vibrations
    By PalmStateCrawler in forum General Discussion
    Last Post: 09-30-2011, 04:43 PM
  4. bad vibration
    By nixdsg in forum Technical Help
    Last Post: 09-12-2011, 07:42 PM
  5. Handlebar Pad
    By Carpit in forum General Discussion
    Last Post: 12-05-2010, 03:38 PM
tw200 handlebar vibration
