Breaking in new tires
Results 1 to 2 of 2
Like Tree2Likes
  • 2 Post By mmclaughlin
Thread: Breaking in new tires
    Member mmclaughlin's Avatar
    Feb 2014
    Flagstaff, AZ
    96
    Hi All:
    Just a tidbit I discovered a few years ago, if everyone else did not already know.
    I have had good luck using Goo Gone to remove the mold release from new tires (that shiny stuff on your new tread that kills your grip). If you just got new tires, and you have some Goo Gone, give them a good cleaning with a rag. It makes the break-in much more pleasant, especially on the outer edges of the tire that don't hit the ground until you are already pushing hard.
    Hope that's helpful,
    Matthew
    r80rt and Adam-n-nevada like this.
    Senior Member Adam-n-nevada's Avatar
    High Desert, Reno area in Nevada
    441
    I like the dirt method too, r80rt. I will keep the goo gone in mind 8k down the road when I get the next. I like the TW in that break-in is pretty minimal, I've never had a close call with new tread on her. The R6 (I had) demanded gentle riding for her new tires! Jeez, the last rear I put on was a dual compound that was a bit harder than the last dual compound. 8 miles on it, less than a block from my house, turning left I lost the rear end and nearly high-sided it when it gripped. I did end up going down but, at least it was the low side.
  1. New tires
    Last Post: 08-03-2013, 02:18 PM
  2. Breaking Up
    By Kenny 1 in forum Technical Help
    Last Post: 07-04-2013, 01:14 PM
  3. Breaking tire beads
    By Mel in forum Technical Help
    Last Post: 06-19-2013, 05:21 PM
  4. Breaking in the new knobs
    By chainslap in forum Trails, Off-road, and Adventure Riding
    Last Post: 05-12-2013, 07:36 AM
  5. breaking the sweat on a sunday
    By dubstep in forum Trails, Off-road, and Adventure Riding
    Last Post: 05-07-2012, 03:20 AM
