turning off the bike
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Like Tree9Likes
Thread: turning off the bike
    Member mrx916123's Avatar
    May 2011
    93
    Do you guys use the key,or the kill switch to turn off the bike?
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Key, why take the chance of wearing out the kill switch...
    Lower Rio Grande, New Mexico
    1,702
    Kill switch, then key. If you ever drop that bike in gear and need it to stop spinning quickly, you will be better off if your instinct is to hit that kill switch, at your right hand. In your garage you can use the key, but when you are lying on the ground with a hot muffler on your leg, the kill switch is faster and more instinctive (if you have practiced it). JMHO. Tom
    elime likes this.
    Central New Mexico
    Senior Member maddawgj's Avatar
    May 2012
    the Coastal Empire (i.e. islands outside Savannah)
    445
    Having watched someone pinned under a 4 wheeler with the throttle pegged open and unable to find the kill switch so we could help him I'll add a +1 to use the kill switch.
    Forever grateful for all your help brother
    2005 TW wrecked in ‘14 and rebuilt in ‘17. ‘06 donor parts and new OEM, Carb jetted & shimmed, ‘04 XT225 gas tank, UNI air filter, Shinko 241 front, modded Krator pegs, IMS folding shifter, JT 14/47 sprockets, huge car horn, tool tube, DR8EIX plug, short rear signals, Cycleracks rear, All Balls steering bearings, Protaper ATV High bars, OEM Kickstarter with more to come...
    Turn the gas off, let the carb run dry, turn the key off when the engine quits. That's my normal procedure.
    Any way possible when the bike goes over, but I usually never give up and make some awesome saves, or at least get the clutch in and bike up before the engine quits.
    Senior Member Indiana's Avatar
    Oct 2013
    Indiana, 40 miles south of Indy
    470
    I use the kickstand.
    Fred likes this.
    Member Crashking's Avatar
    Feb 2014
    63
    Quote Originally Posted by Croatoan View Post
    Why do you let the carb run dry?
    I do the same thing
    Reason I do it is less chance for fuel to go stale and build up gum/varnish inside the carb, plus if it's dry and I've got old fuel in the tank(and know it's been sitting) when I add good fuel to it it'll be better mixed when I turn the valve on and the fuel runs into the carb
    But I also try to add sea foam or stabil to the 2- 5 gallon cans I use most of the time... They get used for the lawnmower, generators, samurai, Atv, TW .... Anything that might for whatever reason sit for a long time... Call it proactive laziness... I don't want to tear anything apart later to clean up a carb when I need something the most
    cabinetmaker likes this.
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,725
    If you don't run it regularly the gas in the carb will gum up the carb. I do this on all engines, lawnmower, pressure washer and such. Leave them sit for a while and you will have problems later.
    Senior Member Hoot Gibson's Avatar
    Dec 2013
    Grand Lake Ohio
    4,416
    So far in my short ownership I have used the kill switch only 2 times....more often than not, I just turn the key....so far, so good! But then again, I have not dropped it{yet} and usually only turn it off in the garage or driveway..
    Hoot's Ride Slide Show Music Videos
    TW Adventure Rides Completed
    March 2015 Moab: With 30 TW Forum Friends..
    Summer 2015 Great Lakes, Wisconsin, UP of Michigan, With Borneo and Montezuma
    November 2015: SE Ohio/West Virginia w/ Borneo and Montezuma
    March 2016: Big Bend NP in South Texas w/ Montezuma, Borneo, Ebbanflood and FW Gary
    August 2016: Montezuma and Hoot's Covered Bridge Ride in Southern Indiana
    Dec 2013
    Grand Lake Ohio
    4,416
    Ok that makes sense. Right now I'm using it more than my car. In my Sportster I try to run the gas tank down so that the next time I run it I'll be using mostly fresh gas. When I run it I usually run a few tanks through it on long rides and then it could sit a month or more. 12 year old bike could probably use some sea foam run through it now and then. I'd already planned on starting to use sea foam on all my rides. Thanks fur da info mate.
    Speaking of Sea Foam, what's a good mix? Does it depend on how old the gas or bike is? I know what the directions say, but last weekend I put about 1/3 can in my 2 stroke mix for my chain saw....smoked like a son of a bitch for awhile... But once that sucker got cranking...the Sea Foam worked great...think I put 2 much in, but the results were not bad....
  1. Turning the lights off
    By rick james in forum Technical Help
    Last Post: 09-30-2019, 02:15 PM
  2. Problem with turning signals / left handlebar switch issue?
    By elasmomark in forum Technical Help
    Last Post: 01-01-2014, 12:23 PM
  3. Turning 50 and getting my first TW!
    By bsullivan161 in forum General Discussion
    Last Post: 05-05-2013, 09:47 PM
  4. Replies: 2
    Last Post: 10-26-2012, 03:12 PM
  5. inverse turning signal
    By dubstep in forum Technical Help
    Last Post: 11-13-2011, 08:48 AM
