MRGIZMOWS folly
Results 1 to 10 of 16
Like Tree18Likes
Thread: MRGIZMOWS folly
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    MRGIZMOWS folly
    I fear I might be getting a reputation as someone that shows up for a ride only to find a reason not to ride. Then again, this might be an opportunity to show folks that when you are handed a lemon, it may be bitter fruit, but it affords you a chance to make lemonade.
    The Cow Mountain ride was a memorable experience for all. I met lots of great people, was awed by what others are willing to do to make sure everyone has a safe and positive experience. As well, perhaps afforded an opportunity to put a smile on the faces of others.
    This is an attempt to chronicle my little piece of the pie. Lots of editing to keep excerpts short, interesting and pertinent to the bike and my experience. Hope you enjoy. Likely, you will get a sense that it turned out to be a enjoyable way to spend three hours in a gas station parking lot.
    As I may be a complete unknown to most, let me assure you, these video's are all done with tongue-in-cheek. I have not and am not selling anything. Apart from the frustration, I am just trying to have fun.
    Gerry
    Segment one:
    Segment two:
    https://www.youtube.com/watch?v=5bx6AKnkV7E
    Perhaps when I say I am a TW kind of guy, I am suggesting that I am Too Weird..........
    Take care my Friend.........
    6,981
    Sounds like it is easily fixable! In other words you don't have to split the case. And there will be more rides.......
    Fred likes this.
    1,110
    Gerry, thank you for the peek into MrGizmow's world. I've always enjoyed the innovative way you see TW world.... and it's nice to 'meet' you. Hopefully we'll see more segments.
    *edit* oops, I just found the two videos you posted in the Cow Mt thread. Thanks for those too.
    Fred likes this.
    Senior Member TWrider's Avatar
    1987 TW200 OHIO
    567
    There is only one way to fix that right, unfortunately it will be expensive. A custom one piece double sprocket where the outer sprocket takes as much of the spline load as possible and the inner is offset on a blind counter. Your way has worked quite a while, but I'd hate to hear that you sheared it out on the road where there is no nearby help, or worse, it causes injury when it lets go.
    You may want to get in touch with this guy and explain what you need....
    Unique Offset Front Sprocket Yamaha Made to Order | eBay
    Fred likes this.
    Member Ready to Ride's Avatar
    Dec 2013
    Pleasanton, California
    54
    There is no innovation without risk.
    It was a pleasure to meet you Mr. gizmo.
    Fred and TW-Brian like this.
    18,813
    Jerry's dual sprocket goal is brilliant, and his prototype validated the concept. Just need a better way of joining both sprockets together for greater durability. Mr Gizmo shall ride again!
    Senior Member rmcglad55's Avatar
    Fleming Island, Florida
    287
    Gee! I feel like I've known you all my life!
    Rusty
    2005 TW200
    2005 Triumph Bonneville T100
    1987 TW200 OHIO
    567
    The best way to join them is not to join them (AKA, make two sprockets out of one piece), or If you want to use standard cheap replaceable front sprockets, use the TTR225 or XT200 counter-shaft, and then use a spline collar and doweled extension shaft with two free-floating stock XT225 sprockets separated by aluminum spacers.
    1987 TW200 OHIO
    567
    The third way is have the TW counter-shaft annealed, and have a machinist extend the splines. The fourth way is (and I have no idea if this would work) assemble it like he has been, but use dowel pins instead of tension pins, make sure the spacer and pins are the right metal, then have the whole thing induction brazed. Just throw it away once it's worn, rinse and repeat.
    Pleasanton, CA
    5,741
    Gerry,
    You were the pioneer of the dual/dual sprocket setup. About how many miles did your first generation design survive?
    Brian
  1. mrgizmows new project
    By Gerry in forum Off-Topic
    Last Post: 11-19-2013, 12:00 PM
  2. mrgizmow's folly
    Last Post: 12-21-2012, 02:19 PM
  3. mrgizmows arduous adventure
    By Gerry in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-11-2010, 10:22 AM
