Virginia Inspection?
Results 1 to 9 of 9
Like Tree3Likes
  • 1 Post By Peterb
  • 2 Post By rbm
Thread: Virginia Inspection?
    Junior Member tequila's Avatar
    Mar 2015
    NOVA
    5
    Just received my plates from Vermont for my '89 TW along with temporary registration. I plan on switching it over to Virginia now that I can request a title and register it. Trouble is that it needs a bit of work before it will pass inspection but I'm not sure what all is a necessity in Virginia to get an inspection completed. Anyone know or know where I can find it? I've googled it a couple of times and searched the Virginia DMV site but no go. Right now the brake light stays on and doesn't change w/brake applied (last PO switched to LED but just plugged it in), there is no mirrors, no rear turn signals, and instrument cluster isn't lighting up. I have an order for turn signals, flasher, diode, and mirrors. The horn is present and does work. Will all of that take care of it or is there anything I'm not aware of?
    Thanks!
    TL
    1990 TW200
    Senior Member Peterb's Avatar
    Apr 2011
    North Bay, Ontario, Canada
    1,484
    Sounds to me like you know what to do.
    tequila likes this.
    Mar 2015
    NOVA
    5
    Thanks, but not having owned a street bike before I don't know what is required and what is optional. I'm use to playing in the dirt!
    1990 TW200
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Brake lights, headlight, and turn signals will be a must no matter where you are.
    Mel and tequila like this.
    Senior Member OurDee's Avatar
    Jul 2013
    North Central Illinois
    814
    Usually have to have one mirror.
    2010 TW200Z : Kick starter, rear CycleRack, 14:47 final w/o-ring chain, shorai 14, Shinko 244 5.10-18 Hidden Content .........
    Mar 2011
    Gobles, michigan
    1,824
    Horn...............Make sure all the signals and hi/low works properly. OMM.
    rbm
    rbm is offline
    Jan 2011
    4,305
    Quote Originally Posted by OurDee View Post
    Yep, forgot about the mirror.
    Mar 2015
    Ynys Môn
    4,591
    The rules are different in the UK – but this should still help you out ……….
    Look at a standard TW200 – and make sure yours has the same kit. Then, if it’s on the bike, it has to work. Yamaha made sure this bike is OK for the USA market. Simples.
    The brake light situation has probably been caused by the PO putting in the wrong kind of LED bulb. Make sure it’s dual purpose tail and brake. They’re cheap as chips, and widely available.
    380 WHITE 24 LED STOP BRAKE TAIL LIGHT BULBS LAMPS 1157 BAY15D P21/5W PAIR 12V | eBay
    The one in the link above is dual purpose, and the peripheral lights illuminate the number plate as well.
    Although the speedo bulb is made of chocolate (e.g. prone to melting), it’s unlikely that that bulb plus the other three have failed. Easy enough to check, just pull them out – they are simple push fit. If the bulbs are OK, then you need to check the wiring connectors (again, it’s fairly simple to do). Making sure the instrument lights are in working order will not only satisfy the examiner, they are there for you as well, and with good reason.
    Sounds like you have the other stuff on order.
    Like I say – work out what the bike is supposed to have – make sure it all works – then you can’t go wrong ……….
    - Hidden Content
    Senior Member Hidebound's Avatar
    Sep 2013
    Lucinda,PA
    394
    If Virginia is like PA they'll check tire tread depth and brake wear too so make sure those are good.
    '01 TW200, '03 Z1000, '09 KLR 650, '13 CRF250L
  1. Hello From SE Virginia!
    By PushingBoulders in forum General Discussion
    Last Post: 08-10-2014, 09:31 PM
  2. Need a top STATOR INSPECTION COVER PLUG
    By docjekyll2002 in forum TW200 Classifieds
    Last Post: 06-11-2014, 08:37 PM
  3. 2005 TW for sale in Virginia
    By GarySeven in forum TW200 Classifieds
    Last Post: 06-03-2012, 07:41 AM
  4. Oil Filter inspection
    By Hoogie514 in forum General Discussion
    Last Post: 01-16-2012, 07:35 AM
  5. valve inspection cover o-ring
    By thumper in forum Technical Help
    Last Post: 11-06-2010, 02:47 PM
Tags for this Thread
