Betty Boop is Back
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Like Tree53Likes
Thread: Betty Boop is Back
    18,828
    Betty Boop is Back
    My TW is finally reassembled and back on the trail after munching it's top end in Moab. Thanks to the enormous generosity of TW-Brian and elime my '03 Betty Boop got a make-over with a reconditioned head and a larger high compression Wiseco piston fit in a 1 mm over-sized old-style cylinder. Tony seems to do good work 'cause Betty sure wanted to romp with greater authority on a quick test ride yesterday. The noted performance improvement may be due to a good valve grind and better, higher compression. Maybe forged piston is lighter? Or crisper air/fuel metering? Anyways bike seems to want to rev up quicker and put out more power in mid to upper range. I may have to adapt my riding style to accommodate as historically I typically played in the torquey bottom end. We shall see. Snowed last night up high, and is still rainy here at 5,200 ft. Will change oil and if rain stops I shall take Brian's loaned valve compression tool to the post office then go get muddy. Vroom!
    Thanks to all for their support and best wishes. Special thanks to Mel and Borneo for loaning me their TWs to get a few more days of riding in while at the Moab group ride. I felt honored by their trust since I had a proven record of recently blowing up Betty twice. And of course tremendous gratitude for the used parts and guidance from Brian and Tony. Tony was so apprehensive that I be pleased with his piston/cylinder pair that he didn't want me to pay until satisfied. What a guy! Great Forum, even better members...thanks.
    Pleasanton, CA
    5,747
    Congratulations Fred, it's great to hear that you are back in the saddle again!
    admiral likes this.
    Senior Member plumbstraight's Avatar
    Montesano, Washington
    2,718
    What a wonderful spirit that TW riders have. Sure makes a person smile.
    HKLBRY, admiral and TWilight like this.
    Senior Member Hikerglenn's Avatar
    Jul 2014
    Smoky Mountains
    297
    YEAH !!!!!!! Betty is alive and well. Awesome to hear Fred. Hope the weather will cooperate and you can give her a good break in.- Glenn
    P.S.- YEAH !!!!!!!!!!!!!!!
    TWilight likes this.
    "Right's right -even if nobody's doing it and wrong's wrong -even if everybody's doing it"
    Mar 2015
    Ynys Môn
    4,591
    Well done to all concerned (and I mean that) – good to see that Fred has the support he needed, (braces aside) when he and Betty needed it the most.
    Fred – may you have many (oil filled) and happy memories on her – (and this time, if she fails you, you’ll know who to blame) ……..
    - Hidden Content
    Senior Member Joemama's Avatar
    Apr 2012
    Lake County, Ca.
    1,249
    Fred, you could load the old girl up and go to the wrench and ride next weekend. Good time to return the tool, swap parts and get caught up with the b.s.
    Frosty Hollow
    13,088
    Fred,
    So glad you got Betty Boop up and running.beer.gif Huge kudo's to TW-Brian and elime, almost makes me tear up reading about the success! Almost!fpalm.gif
    I feel bad the head I sent you was defect and hope I didn't wreck it somehow before sending it your way. It sure didn't last long. Did both your original head and my replacement have the same fault/problem? If so, any idea what it could have been on them?
    Anyway, so glad you're back up. It was so great Borneo and Mel loaned their TW's to you, but I know you probably had a weird feeling of what had happened to yours. If anything, your gaining a ton of engine repair/replace experience.
    Time to zip up the jacket, throw a leg over the saddle, and head on down the trail.
    Take Care
    Fred, TWilight and Gerry like this.
    18,828
    Not fault of admiral's head. Loose adjuster nut on intake caused problem, not stripped exhaust cover bolt and low oil level I think. I didn't tighten things up enough after playing with Gerry's gift of a valve adjusting tool.
    Mel
    Mel is offline
    Senior Member Mel's Avatar
    Jan 2013
    San Luis Obispo, Calif.
    1,174
    Fred,
    I knew with rusty nuts the size of yours, Betty Boop was destined to run. Glad to hear you are on the road again. I road that white TW of mine the other day, and couldn't tell you had even been on it!
    Mel
    TWilight and DonBenito like this.
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    Glad your fixed and riding again. Just in time for Summer....
    TWilight and plumbstraight like this.
    Bob
    When in doubt, Gas It..!!!
  1. What is wrong with Betty Boop ?
    Last Post: 04-07-2015, 03:49 PM
  2. Anther Rocky Sandy Video With Betty
    By Fred in forum Trails, Off-road, and Adventure Riding
    Last Post: 12-23-2014, 02:58 PM
  3. Betty's Favorite Rock Grotto
    Last Post: 11-10-2014, 09:20 AM
  4. Betty Boop lied about her weight.
    By Fred in forum General Discussion
    Last Post: 08-20-2014, 12:12 AM
  5. Back up her backside! The back way! Now with GoPro time-lapse pics.
    By DonBenito in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-16-2013, 10:23 PM
