Back brake seems inadequate
Results 1 to 9 of 9
Like Tree11Likes
  • 1 Post By munchmeister
  • 2 Post By SHAG
  • 1 Post By jb882
  • 2 Post By OurDee
  • 2 Post By RockyTFS
  • 1 Post By Werloc
Thread: Back brake seems inadequate
    Junior Member jimv3845's Avatar
    Apr 2015
    I bought a 2015 TW200 a few weeks ago. It's my first motorcycle in many years. To me the back brake seems too small to really do the job. Even when I press on it pretty hard the best I hope for is that it slows me down. I find myself using the front brake quite a bit because the back brake just doesn't seem to be doing the job. I get the feeling if I had to make an emergency stop I would be in big trouble. Do others feel this way besides me? Thanks
    Senior Member munchmeister's Avatar
    Mar 2015
    206
    It's an old school drum brake. Whaddya gonna do. It is what it is. At least you'll have a hard time skidding with the rear brake.
    TWilight likes this.
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    971
    My rear brake seems to work pretty good on my 2013, but it's the front brake on mine that seems inadequate. I guess I'm used to the double front servos on my GS.
    TWilight and liljohn1998 like this.
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Senior Member jb882's Avatar
    Aug 2013
    1,377
    The front is where over 80% of the stopping power is, you should be using more front than rear.
    The TW's brakes are ok, not great but good for what that are stopping. I personally don't feel that i would have a problem in a true panic situation.
    If you want to talk about horrible rear brakes, take a Ducati Multistrada like mine for a ride, the rear brake is useless. Its literally merely a compliance item to make it road worthy. Thankfully the front brakes are superb. I almost never use the rear brake on this bike except for really slow speed for control or to hold it on a hill.
    liljohn1998 likes this.
    Apr 2015
    Thanks
    Senior Member OurDee's Avatar
    Jul 2013
    North Central Illinois
    814
    Plenty of rear brake if used in concert with the front. Practice, practice, practice.
    TWilight and DANo896 like this.
    2010 TW200Z : Kick starter, rear CycleRack, 14:47 final w/o-ring chain, shorai 14, Shinko 244 5.10-18 Hidden Content .........
    Hailey, ID
    3,376
    Quote Originally Posted by jimv3845 View Post
    Thanks
    In dirt or even pavement under 10 mph, the rear should be able to lock up every time. It should engage at about 1/2" of pedal travel, so check that first....If it is that new, it is probably not broken-in. Use it to stop from moderate speeds at least a couple dozen times without the front brake, first at moderate pressures, then at increasing pressures. This is VERY important to avoid glazing the shoes.
    If it still won't lock up in dirt from 10 mph after that, you will need to pull the wheel and look at the shoes to see if there is really uneven wear....sometimes the shoes can be mis-aligned to the drum.
    If you don't see any uneven wear, sand the shoes with 320 grit, using a block of wood carefully held parallel, just to the point of taking the sheen (glaze) off (probably only a dozen strokes), and start over.
    TWilight and Hidebound like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member TWROG's Avatar
    Dec 2014
    Stockbridge GA
    807
    ^^^^ I did similar on both my TWs though dont know if I was that precise. Neither bikes rear brakes would lock no matter how hard I stomped on it. So I started adjusting until a good amount of pressure would make it lock. By good amount I mean more than I would ever use in "normal" riding.
    2009 TW200 "Cracker" - His fun ADV bike
    2006 TW200 "Blue" - Her fun ADV bike
    2011 XL1200X "48" - My cool bike
    1977 KZ650 - My vintage sport bike
    Senior Member Werloc's Avatar
    Nov 2013
    Central, NJ
    1,983
    Like said above, front brake does 80% of your braking due to most of the weight is transfered to the front while braking. I hardly ever us my rear brake. Only as added braking in "Panic" oh crap, I ain't stopping situations. I use it more to lock rear wheel to slide into turns while riding agressive in the dirt. Mine locks up pretty easy when I need it to. You should get use to using your front brake if you really want to stop.
    Smitty Blackstone likes this.
    Bob
    When in doubt, Gas It..!!!
  1. Replies: 1
    Last Post: 02-08-2015, 06:36 PM
  2. I'm back
    By longroof in forum General Discussion
    Last Post: 12-20-2013, 02:42 PM
  3. Back up her backside! The back way! Now with GoPro time-lapse pics.
    By DonBenito in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-16-2013, 10:23 PM
  4. Looking at getting back on a TW
    By chickenwingsmmm in forum General Discussion
    Last Post: 09-07-2012, 04:52 PM
  5. I'm almost back, i think...
    By weather_man in forum General Discussion
    Last Post: 05-22-2011, 05:52 AM
