Hmmm, decisions, decisions...looking for advice
Results 1 to 10 of 19
Like Tree14Likes
Thread: Hmmm, decisions, decisions...looking for advice
    Senior Member Jaydub's Avatar
    Apr 2015
    SE Wyoming
    112
    OK, been reading up a lot on the TW's and want to get one. Been doing some scrounging and have come up with two good possibilities locally. Even so, I have a few questions. I want to get a TW in decent shape, low miles, and would like to add a nice rack on the back, Clarke Tank, and heated grips. Once you ride with heated grips it's nearly impossible not to have them in the northern climates.
    Here's what I've scrounged:
    1. 2000 model with under 500 miles, like new, all stock and has OEM rack (that I'd probably sell) $2k obo
    2. 1993 model with under 3k miles, a little surface rust here and there, no farkles at all, for $1200 obo.
    I've been thinking I'd like a 1988-2000 model to have the kickstart already installed. Reading through some forums I see CDI units fail and are hard to come by for the 88-2000 models (perhaps that was just a snapshot in time and they are easily found now). I know the 87 models had a lot of CDI failures but I was reading through some threads where the 88-00 are failing now and parts are hard to find and expensive. Are they still hard to find?
    I also have a question about the charging circuits. Can the charging system output supply enough electricity to run the headlight, taillight, charge the battery and also the heated grips? The ones I've used on 2 BMW bikes are the Symtec 36w units. Perhaps I'd need to add a switch to turn off the headlight & taillight for when using the heated grips. I haven't found the charging circuit output for the different models.
    Would I be better to look for an 2001-15 for the newer charging circuit, newer CDI, then add the kickstart for ~$300?
    Thanks in advance for any advice. You folks are a helpful bunch so I know you'll have advice and some humor too.
    Thanks,
    Jay Dub
    TWilight likes this.
    Jay Dub
    Current rides:
    '01 TW200 bone stock
    '06 Honda CRF230F lighted & plated.(KISS where less is more)
    '01 BMW R1100RL with Russell "Day Long" saddle, Aeroflow screen, heated grips, throttle lock, modulating headlight & tail light.
    Previous rides:
    '87 BMW K100LT, '03 Honda XR650L, '95 Honda XLR250R "Baja," '71 BMW R60/5, '81 Honda CM400C "Custom," '82 Honda ATC 185S, '79 CR125 Elsinore, '79 KE175,
    various others I don't remember the models
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    IMO, I'd look for a 2001+ for the electrical system if you want heated grips. I have an '05 and added grips and an LED headilgit to free up some amperage for the grips and heated jacket liner. The kicker will cost you a little over $200 from Bay Area.
    Mar 2015
    Ynys Môn
    4,591
    I'm on a '98 - and converted the headlight and tail light to LED to free up some amps - but I think the bike would still struggle with heated grips
    I'd say go with rbm's suggestion - it's a lot easier to add the kickstarter rather than fart about with the older style 36w electrical system. Wouldn't worry about the CDI - only the '87's are prone to fail - and replacements are available for $150 if you get unlucky on a newer model
    The only other major difference between pre-2000 and post 2000 is the introduction of a CV carb - the new ones are smaller and a bit fiddly but set-up correctly and they're OK
    jtomelliott49 and TWilight like this.
    - Hidden Content
    Apr 2015
    SE Wyoming
    112
    Thanks for the input. I appreciate it.
    The 2000 that was "like showroom new" turned out to not be quite so showroom. Not at all really so I passed on it. I'll look at the 93' soon just because of price, otherwise I'll try to look for an early 2000's model. I've got to keep the BMW rider image going....what's the cheapest thing on a BMW motorcycle?
    THE RIDER!
    Jay Dub
    Bagger likes this.
    Jay Dub
    Current rides:
    Previous rides:
    Senior Member sponge's Avatar
    Apr 2015
    Mesquite Nevada
    636
    Quote Originally Posted by Jaydub View Post
    THE RIDER!
    Jay Dub
    LOL We have to be. BMW thinks their parts are all made of gold
    Apr 2015
    SE Wyoming
    112
    Quote Originally Posted by sponge View Post
    Yes, that's why we have the alternative parts list handy to use car parts on the bike where we can. Of course I ride older BMW bikes and don't worry about oem parts if I don't need to. My bike has a Purolator car oil filter that meets the same specs as oem, autolite spark plugs, etc.
    Jay Dub
    Current rides:
    Previous rides:
    Senior Member Mkfchef's Avatar
    Aug 2014
    Laurel, Ms.
    210
    I would go look at a 2015 if I was you. Color scheme is awesome and dealers are always glad to have someone take a slow moving TW off their hands. Ergo you can get a really good deal from a dealer that only sells these oddball bikes because he has to.
    OR you could wait for the 2016 to come out! It's going to be fuel injected! ....yeah right
    May 2014
    Yooper, MI
    1,510
    Having ridden big heavy dirt bikes with no electric start, and remembering all those times I cursed those bikes for not having one, I just do not understand the enamoration some have for a kick start on this bike. I can jump/push start it by myself, up hill, both ways, bare foot, in the snow.
    Peterb likes this.
    Senior Member Tuber's Avatar
    Sep 2012
    VT
    736
    check the classifieds on here too...a lot of us see bikes for sale and post them. One guy in the UP has a newer model for sale
    2005 Tdub
    May 2014
    Yooper, MI
    1,510
    If there's something up here in the UP you want me to scope out for you let me know. I was looking for over a year and finally settled on the 2002 with 770 miles, for $2400 that you see in my icon. I let a couple of good deals get away.
    I think this is hte one Tuber is talking about....https://tw200forum.com/forum/tw200-cl...-michigan.html
    2006. Already has the kick start installed
    Here's one that I was looking at. It's down state. I think this is the second listing for it so the guy might be willing to accept less.
    http://nmi.craigslist.org/mcy/4999532275.html
  1. Decisions decisions....
    By Flathats in forum General Discussion
    Last Post: 07-17-2014, 05:28 PM
  2. Thoughtful decisions redux. Why not ride a TW?
    By Borneo in forum General Discussion
    Last Post: 02-17-2014, 08:16 PM
  3. Thoughtful decisions, Why ride a TW?
    By Polarpilot in forum General Discussion
    Last Post: 02-17-2014, 07:23 PM
  4. Husqvarna vs. KTM... decisions, decisions
    By PalmStateCrawler in forum Off-Topic
    Last Post: 12-03-2013, 10:53 AM
  5. Need advice getting a used TW 200
    By Boret in forum General Discussion
    Last Post: 09-01-2010, 09:29 PM
