Switch panel?
Results 1 to 5 of 5
Thread: Switch panel?
    Junior Member AveCat's Avatar
    Jun 2015
    1
    Switch panel?
    Anybody fabbed up a switch panel for the TW? Like for an aux light or two?
    Senior Member OurDee's Avatar
    Jul 2013
    North Central Illinois
    814
    Why not eliminate the idiot lights and put it there? The three lights to the right of the speedo. Great place for a roll of toggles.
    High beam indicator, Look at the switch position on the left bar.
    Turn indicator, I can see the front signals while seated.
    Neutral indicator, Rock the bike back and forth.
    Yep, I don't need them.
    I have a garrage door opener in mine with a momentary switch mounted on the side. It still has the lights in it. I haven't figured out anything else I want on the bike. So, I've not pulled the lights.
    2010 TW200Z : Kick starter, rear CycleRack, 14:47 final w/o-ring chain, shorai 14, Shinko 244 5.10-18 Hidden Content .........
    Senior Member SHAG's Avatar
    Oct 2013
    Bradford, Pa
    969
    Anyone need a Farkle Bar?
    2013 TW200 - 8k- miles
    2018 X-MAX - 6k- miles
    Apr 2011
    Martinsville Indiana
    2,089
    Here is a pic of my setup. Left switch is a on/off switch for the low beam. Middle switch is is the on/off for the relay switch for the led running lights and the far right swith is a 3 way switch for the heated grips. up is high middle is off and down is low.
    Here is a link to my install https://tw200forum.com/forum/performa...r-install.html
    Apr 2011
    2,089
    If i was to do it again i would probably use one of the cyclops led bulbs but they werent out when i did mine. Here are some night time photo comparisons to show the difference.
    https://tw200forum.com/forum/performa...on-photos.html
  1. Clunk from instrument panel at every bump?
    By PalmStateCrawler in forum Technical Help
    Last Post: 11-07-2017, 04:47 AM
  2. Large Stainless Steel Panel Box
    By Dell in forum TW200 Classifieds
    Last Post: 06-07-2014, 04:16 PM
  3. Toggle Switch Panel
    By ronnydog in forum Performance and Customization
    Last Post: 09-30-2011, 11:20 PM
  4. WTB left side panel
    By brownie2 in forum TW200 Classifieds
    Last Post: 10-07-2010, 06:10 AM
  5. Kill Switch, Kickstand Switch, Clutch Switch
    By twmonae in forum Technical Help
    Last Post: 08-16-2010, 06:50 AM
