Suggestions TW200
Results 1 to 10 of 11
    Member bradbeer's Avatar
    Mar 2011
    Elkhart, IN
    44
    Hello all
    I want to sell my bike and get something fun to ride to work and around town. From all of the disscussions and things I read online, people just absolutely love tw200's. I am a little worried about speed/power, but that is partly why I want to get this anyways. A lot of people talk about changing the sprocket thingie (sorry not the handiest of guys) to get more top end. I may (rarely) want to get on a highway for a few miles (certainly not a road trip or anything). My question is does changing this size make the get-up-and-go a lot less/lose some of the low end torque?
    I am 6'6" 250 lbs. Am I too big?
    For some reason as I get older and now have 3 kids I never really feel like going fast on the road or wheelies or anything, I lost my nerve I guess, so I just want something fun and want to hit the dirt every-so-once-in-a-while.
    I know they said it is rock solid bike and that has mainly not changed over the years, but is there any suggestions on a year or year range I should consider? I want it up and running, road and off-road ready.
    Thanks for any feedback.
    Just got TW200 4/2/11! First bike I have owned capable of hitting dirt/trails
    97' TL1000s and 94' FZR 600
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,406
    Quote Originally Posted by bbb View Post
    ... I lost my nerve I guess,..
    No, you have come to your senses and become wiser.
    Look for a low mileage 2001 or newer.
    jb
    Senior Member dhoenisch's Avatar
    Chicagoland, IL
    512
    If it helps, I am 6'2" and about 230lbs last time I checked (though my pants are getting tight again). I did do a couple of upgrades. The first one was to add some mirror risers/extenders that I got off of eBay. With the mirrors in their stock position, all I could see were my arms, so that took care of that issue. Than, another member on this board sent me his unneeded 1" handlebar risers, which completed it up front for me. Then I added a Stearns ATV seat pad. It widened the seat, so it made it more comfortable for me. I've had the bike up to 55mph with stock gearing, but I also purchased a 47-tooth sprocket to add once the weather breaks.
    Also, I'm going from a 500cc Honda cruiser to this bike. I love it. It's the first motorcycle I had ridden when I took the motorcycle safety course, and I just had to have my own.
    Well, hope this helps.
    Dan
    2009 Yamaha TW200
    1996 Yamaha Virago 1100
    The stock sprockets are good for 74mph at redline. Really doesn't matter what sprockets you run, the engine won't pull 74mph unless downhill with a tailwind, so for any other conditions a sprocket change for more top end is pissing in the wind. Replace the stock chain and call it good as far as top end goes, unless you often ride long, fairly steep downhills on roads straight enough to run over 74mph.
    A real reason to change sprockets is to increase the functionality of 1st gear--a lower ratio will increase low speed torque multiplication offroad while a higher ratio will increase the speed in each of the lower gears before necessary to shift on the street. Either one tooth added to the countershaft sprocket or 3 or 5 teeth off the rear wheel sprocket--not both, and any more than that will cause problems with the wide gap between 4th and 5th and increase clutch wear rate.
    Another reason to change sprockets is to reduce vibration, but as tall as you are you'll want taller bars, anyway, so get a aluminum bars and a pair of gel grips to tame the vibration.
    People complain they can't stand to hear the TW engine scream along, but it doesn't bother the engine. That's a problem with the people, not with the TW. What hurts a TW engine is chugging along at the same rpm as a 650.
    Mar 2011
    Elkhart, IN
    44
    Need opinion please
    Found a 2004 tw200 only about an hour from me. I have not seen it but looks great condition and he says runs great and looks perfect (like new), only used camping and a little on the road (he did have it plated and registered). He is asking $2,300 obo which seems a little high for 7 years old but it only has 350 miles on it.
    I guess my fear is after 1 summer if I put on 2,000 miles then it is back to average bike for its age and worth $1,000, maybe that doesnt matter im not really looking for an investment but I like to buy and sell stuff and get decent deals.
    Or is a 7 year old bike that has been sitting still age the same or maybe worse anyways so the value still should fall?
    Any thoughts would be appreciated. Thanks
    Senior Member Mhurchu's Avatar
    Sep 2010
    Dublin, Ireland
    112
    Hi
    dhoenisch, I'm 5'7 and 120lb's and I can only see my shoulders thru the mirrors.
    Need opinion please
    A motorcycle is not an investment. A motorcycle you actually want to ride only makes financial sense if you have to have transportation and choose a motorcycle instead of a car or truck. Other than that, either buy because you want to ride or don't waste your money.
    Chicagoland, IL
    512
    Quote Originally Posted by O'Mhurchu View Post
    Hi
    Huh, I stand corrected. Makes me wonder why they never corrected that. Oh well, at least there's a cheap and easy fix out there,
    Dan
    2009 Yamaha TW200
    Senior Member jeffreyloxley's Avatar
    Mar 2011
    Arizona
    100
    Need opinion please
    I've only owned my TW200 for a month and this is the first one, but personally, I don't believe 2300 is bad for a TW with only has 350 miles on it, no matter how old it is. Where I live, a brand new one costs 4000. He did say OBO, so haggle with him a little and see what you get.
    Good luck, Jeff
    2010 TW200
    Senior Member Matojo's Avatar
    NW Arkansas
    216
    I also sold my bike to get something fun to ride around town, to ride to work , trash the woods around here and I got no regrets of any kind, this bike is so much fun. My coworkers with big bikes think Im crazy but all of them like my bike and wish they can have one to. At 5.8 and 155bls this little machine suit me just fine and the only mods done to it so far are:a MSR skid plate and IMS folding shifter, I have big feets so a set of wide pegs are nex.
    I think the price is right and you may get it low with cash in hand.
  1. Bar End Suggestions?
    By hoginthebog in forum Performance and Customization
    Last Post: 04-23-2013, 08:33 PM
  2. New owner, new driver, need some suggestions
    By sleepingbear in forum General Discussion
    Last Post: 08-30-2012, 11:17 AM
  3. Need some suggestions for lowering a TW
    By greenstang232 in forum Performance and Customization
    Last Post: 05-31-2011, 10:00 PM
  4. Looking for tire and tube suggestions
    Last Post: 05-14-2011, 10:22 PM
  5. Tire and rack suggestions needed!
    By Hobopoet in forum Technical Help
    Last Post: 02-05-2011, 09:08 PM
used tw 200 yamaha fat tire 10 yrs old
