Which Bigger Sprocket
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 61
Like Tree36Likes
Thread: Which Bigger Sprocket
    Junior Member kingtw's Avatar
    Aug 2015
    11
    Question Which Bigger Sprocket
    Hello TW nation.
    I mainly use my TW200 for single track trail riding. Many of the trails have steep inclines and I often loose RPMs really fast and will die before getting to the top. I just have a stock sprocket on right now and I am pretty sure I need to go with a bigger one. I am not a small guy at 6'4" and 205lbs, but I would like more low end power to get up some of the steep hills. Is going to a 52 tooth sprocket big enough or should I jump to a 55 tooth? Can you guys give me some advise on what size and brand sprocket to go with?
    I found this one on Amazon, has anyone used this one?
    http://www.amazon.com/JT-Sprockets-J...ype=motorcycle
    Thanks for the help.
    Vacationing in the Bahama's
    17,573
    Quote Originally Posted by kingtw View Post
    Hello TW nation.
    Welcome to the forum!! Where are you from?
    Here is a sprocket calculator that might help you determine what might work best.
    Sprocket Calculator - the easy motorcycle sprocket and chain calculator
    Personally, I think the 55 would suit you better.
    A 52 would give you 3.8% difference, a 55 would be a 9.1% difference.
    kj7687 likes this.
    1st John 1:9
    John 3:16
    John 3:17
    rbm
    rbm is offline
    Senior Member rbm's Avatar
    Jan 2011
    4,305
    Hello and welcome! What LT said^^.
    littletommy likes this.
    Stanwood,Wa
    1,898
    I'm thinking 55
    Gen:27:3
    “I've noticed that everyone who is for abortion has already been born.”
    -Ronald Reagan
    Apr 2014
    992
    Welcome kingtw;
    When you say "mainly"; we need to know the other end also. I would venture to say that most on here that want lower off-road gearing go with a 55 tooth rear. I bought one to play with and then decided to get a 65 tooth to try (harder to find and more expensive).
    I love the 65 tooth off-road. At Fred's last group ride; as we came down a steep incline from Crater Lake south of Tahoe - me not using brakes in 1st gear, I was falling behind those who were "riding" their brakes constantly while in 1st. I would have to shift up to 2nd to close the gap.
    To be in the peak torque and HP range with stock gearing - I think you need to be doing around 16 mph in 1st gear; and faster in 2nd etc. About wound out in 1st and way to fast in each gear for our suspension on rough trail conditions. The 65 tooth brings you closer to the torque/power band at lower speeds and should keep you from stalling.
    However; I really dislike riding around city streets at more than 35 mph with that sprocket.
    So it will depend on if you get on the freeway some or just 55 mph roads or if only 35 mph roads and hard trails. 35 mph street and hard trails gets my vote for 65 tooth. Otherwise probably no less than 55 tooth if you want lower gearing. -J-
    19,019
    I just put on your chosen sprocket, JT Sprockets JTR1842.55 55T Steel Rear Sprocket. It is my second one, for some reason it arrived silver finish not the black I thought I ordered, oh well. Anyways it is a good choice for your stated intended use. Sixty Five teeth in the rear makes for a real off road crawler, I have ridden two TWs so equipped and while very versatile off road I imagine it kills a lot of the dual sport nature of the TW.
    Personally I have a 13 tooth front sprocket but a larger diameter ATV tire in the rear so my overall gearing approximates what a 14/60 with stock tire would deliver.
    Banned ZDR1's Avatar
    Feb 2014
    Arizona
    4,030
    So if you went to a 55 is the stock chain long enough ?
    Pleasanton, CA
    5,777
    Hi King, welcome to the forum!
    I have used sprockets from JT and Sprocket Specialists. Both are good quality sprockets. Some sizes are available in both steel and aluminum. The larger sizes seem to only be available in aluminum.
    I have run the following sizes of rear sprockets with the stock 14T front and a Duro 26x8x14 ATV tire. Here are some of my impressions:
    47T - An improvement for highway use. Doesn't noticeably increase top speed but reduces rpms so the ride is not so buzzy. Not good (i.e., dangerous) for steep trails.
    50T (stock size) - Good combination for mix of street and moderate fire road type trails.
    55T - Nice improvement for steeper off-road riding while still allowing short highway hops at 55-60mph.
    65T - I absolutely love this for off road. Makes steep, gnarly downhills an actual pleasure to ride. Limits on-road top speed to about 50. If you don't care about going over 40-45mph on-road, I would even consider a 70T which is the largest that I seen anyone use.
    I run the dual rear sprocket setup. Here are a couple of pics showing two of the combinations that I have used:
    Here is a 47/55 combo,
    Here is a 55/65 combo,
    Pleasanton, CA
    5,777
    Quote Originally Posted by zdiver1 View Post
    Sorry Paul, but I don't believe the stock chain will be long enough.
    I switched over to an o-ring chain when I got my 55T sprocket.
    ZDR1 likes this.
    6,998
    Give the stock chain a try. I was using the same chain for 50 and 55 teeth.
  1. Need Something Bigger and Stronger
    By Mongol Pete in forum TW200 Classifieds
    Last Post: 07-07-2014, 11:26 PM
  2. Is $2500 too much to pay for a bigger tank?
    By old white truck in forum TW200 Classifieds
    Last Post: 05-18-2014, 01:10 AM
  3. Bigger engine in the TW
    By Dako124 in forum Technical Help
    Last Post: 09-20-2013, 11:50 AM
  4. bigger pilot jet?
    By DDavis in forum Technical Help
    Last Post: 10-25-2011, 02:02 AM
  5. Bigger front tire?
    By movingtarget in forum Performance and Customization
    Last Post: 10-09-2010, 02:33 PM
sprocket combo for mountain trails
tw200 larger chain and sprocket
tw200 larger sprocket
yamaha tw 13 tooth front sproket
