Bag supports for Cyclerack
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Like Tree24Likes
Thread: Bag supports for Cyclerack
    Senior Member JasonTX's Avatar
    Jan 2011
    League City, TX
    282
    Are there any DIY ideas floating around to make bag supports for the Cyclerack? I think that the ones that they make are overkill for my intended purpose. I will be using Nelson-Rigg dry bags not hard cases, so I want simplicity. Any advice will be appreciated! J
    The Southwest
    566
    Overkill? I've bent mine.
    Frosty Hollow
    13,174
    I used a metal rod from the local hardware. I bent and cut it to fit. Is very fast to put on and take off. I must admit I don't know if this will work for you as I don't haven't seen Nelson-Rigg Bags, but maybe this will help.
    Attached to my saddle bags
    Good Luck
    Jan 2011
    League City, TX
    282
    Thanks for the great advice gentlemen. Admiral, I think that what you made is exactly what I am needing. Can you tell me the diameter of the material that you used and how you went about bending?
    Frosty Hollow
    13,174
    Rod dia. I think was 3/8 but I'll check when I get home. If it's different I'll post it up. I used a Oxy/Act torch to heat it up and made the bends. Yeah, don't hit the "cut" button on the handle. I think I made the curls by heating the rod up then bending it over, up and around, using the actual cyclcrack as the guide. I wore welding gloves and used a vice grip and...hammer, to manipulate the curls. I used a hand grinder to smooth out the cut portion of the rod.
    I started out using a torch which attaches to one of those small hand held propane tanks and it was working. It's just the Oxy/Act torch heated it quicker.
    Oh, and I just eyeballed the measurements to match my saddle bags.
    littletommy and Fred like this.
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,413
    it's really the hammers that had him pinned to the ground, not the rack
    littletommy and admiral like this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Frosty Hollow
    13,174
    A connoisseur!
    ZDR1 and keithmaine like this.
    Oct 2014
    Armstrong BC
    2,413
    looks like a smorgesboard
    admiral likes this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Jan 2011
    League City, TX
    282
    It is not stated on their website, but are the Cyclerack supports $79 for the pair or the individual? If it is for the pair I'm going to buy them, if it's $79 per side Im going to mimic admiral's set up.
  1. Saddlebag Side Supports
    By M C Toyer in forum Performance and Customization
    Last Post: 10-17-2015, 12:15 AM
  2. WTB Bag supports for Cyclerack
    By dette in forum TW200 Classifieds
    Last Post: 06-08-2015, 04:26 PM
  3. WTB: Cycleracks Bag Supports
    By cololevi in forum TW200 Classifieds
    Last Post: 01-21-2015, 06:15 PM
  4. FS: Cycleracks bag supports
    By turborob in forum TW200 Classifieds
    Last Post: 10-28-2014, 05:23 PM
  5. Cycleracks Bag Supports
    By retmotor in forum Performance and Customization
    Last Post: 02-12-2014, 06:48 PM
cycleracks bag support
cycleracks bag supports
rotopax
