Change that oil ASAP!!!!
Results 1 to 6 of 6
    Member michael's Avatar
    Québec, Canada
    62
    Ever think about waiting to change that break-in-oil, change it know!!!!! this is after a 5 minute break in on a new crf230f. Those are some big chucks.
    The journey is more important then the destination and to have someone to talk to about your journey is the most important of all. Enjoy every day and keep riding.
    Lower Rio Grande, New Mexico
    1,702
    The big chunks are safely caught up in the filter screen. Its the little fellows you can't see that are chewing on your bearings. You are just doing the final polishing of the cylinder walls. No problem. But by the same token oil is relatively cheap and you can change it as often as YOU want. Tom
    Central New Mexico
    Desert, SoCal
    7,369
    This is becoming a common issue as more and more manufacturers have resorted to silicone sealants. Engines are assembled with liquid sealent, the parts torqued down and the bikes shipped. The excess hardened sealant eventually breaks off and finds the oil screen, a process which often continues long after initial break-in, and on occasion to such a degree that it clogs the screen sufficiently to cause catastrophic failure.
    China, Thailand and others have increasingly become Japan's "Mexico" with bikes being assembled and/or manufactured offshore for their reduced labor costs. Nightmare stories of entire runs of bikes leaving the assembly line sans oil filters, pickup screens (backward clutch arm springs?) and the like are increasingly common, so it pays to check. Trust not thy dealer, who chargeth for setup, but checketh not.
    As the man from N.M. stated, oil is cheap.
    Québec, Canada
    62
    Cool info guy's! To bad the japanese machines have lost some quality over the years, but I still love there products.
    1,110
    When I got my bike it had 236 miles without a first oil change. The screen had some debri but not that much. The oil had a lot of metallic look though. Thanks for the reminder.
    ....a little off topic.....what country is the TW plant in?
    Member bend42's Avatar
    86
    ...The excess hardened sealant eventually breaks off and finds the oil screen, a process which often continues long after initial break-in, and on occasion to such a degree that it clogs the screen sufficiently to cause catastrophic failure.
    Just did the first oil change on my 2010TW at 250 miles, 99% on dirt. The screen was noticeably clogged, with what I did not know until reading the above. Lots of small metallic shavings on the filter itself.
    Oil is cheap and I want to run this bike along time and a lot of miles.
  1. Oil change
    By osheen23 in forum Technical Help
    Last Post: 04-24-2016, 11:23 AM
  2. Replies: 0
    Last Post: 02-03-2013, 12:28 AM
  3. Cam change?
    By RingSteel in forum Technical Help
    Last Post: 01-22-2012, 09:19 PM
  4. Please help asap
    By Daltoncoody in forum Technical Help
    Last Post: 05-11-2011, 08:18 AM
  5. WTB - Muffler - need ASAP
    By Rohnsman in forum TW200 Classifieds
    Last Post: 09-01-2010, 01:51 PM
