Airbox holes
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 32
Like Tree56Likes
Thread: Airbox holes
    Junior Member Mywasp's Avatar
    May 2013
    4
    Airbox holes
    Should they be taped over?
    Frosty Hollow
    13,052
    Yes, most likely they should be taped over or otherwise plugged
    TWilight likes this.
    Apr 2011
    Martinsville Indiana
    2,089
    You can get solid rubber plugs at ace hardware or whatever your local hardware store is..
    admiral likes this.
    Frosty Hollow
    13,052
    Ignore
    18,719
    The stock air box's snorkel intake is not really restrictive. However if one makes the assumption that is and drills holes to somehow try to let more c.f.m. in ( it really won't), why would one think this extra cubic feet per minute of air will somehow make the bike run leaner?
    If one assumes one gets higher air flow rates through the carburetor it will just stimulate more fuel to be sucked through various fuel circuits resulting in same stoichiometric ratios, just at a higher c.f.m. One has to remember the Bernoulli principle and how it makes our carburetors work. Increasing the air flow rate for any given throttle opening will be accompanied by a corresponding increase in the fuel flow rate; it will not alter the air/fuel ratio which is determined by all the fuel passageway orifice sizes, not air flow rates.
    I know there is lots of shade tree wisdom and old wives tales repeated out there, also lots of gimmicks for sale. Doesn't mean they work.
    If one wants to lean out the air/fuel mix one needs to change the fuel metering to reduce fuel delivery rates. Simply trying to cram more air through simply grabs more fuel with that additional air; the ratio is mechanically fixed by the physical geometry of the various fuel orifices all driven by suction caused by the air flow according to the Bernoulli principle. Besides the drilled holes let more induction noise out while allowing a tiny bit more debris and air in.
    Frosty Hollow
    13,052
    If one assumes one gets higher air flow rates through the carburetor it will just stimulate more fuel to be sucked through various fuel circuits resulting in same stochiometric ratios, just at a higher c.f.m. One has to remember the Bernoulli principle and how it makes our carburetors work. Increasing the air flow rate for any given throttle opening will be accompanied by a corresponding increase in the fuel flow rate; it will not alter the air/fuel ratio which is determined by all the fuel passageway orifice sizes, not air flow rates.
    If one wants to lean out the air/fuel mix one needs to change the fuel metering to reduce fuel delivery rates. Simply trying to cram more air through simply grabs more fuel with that additional air; the ratio is mechanically fixed by the physical geometry of the various fuel orifices all driven by suction caused by the air flow according to the Bernoulli principle. Besides the drilled holes let more induction noise out while allowing a tiny bit more debris and air volume in.
    Anyone's seat-of-the-pants opinion seems more wishful thinking than anything that can be substantiated by imperial evidence and the physics of fluid mechanics.
    Fred,
    Despite your thinking that drill holes in the airbox cover won't work, I'm telling you it does. As it was about 10 years ago when I tried it, I can't for the life of me remember who it was here on the forum that suggested this idea with the airbox holes.
    But I did indicate the best way was to re-jet and the airbox holes should be considered only temporary.
    If you get a spare airbox cover, try drill holes in it and see if you can tell the difference. I'll even loan you my modified airbox for you to test. Now, I'm not gonna say you will fall off the back of your TW when you crack the throttle, but you will be able to hear the difference even at idle with a slightly higher rpm.
    TWilight and grewen like this.
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    801
    I can not see the TW200 able to utilize a less restrictive air flow than what is stock. The motor just isn't capable of pumping any more air through than is already available. I recommend plugging the holes and maintaining the air filter regularly.
    The bear slayer!
    Frosty Hollow
    13,052
    OK, I am wrong and you all are right.
    Apr 2011
    2,089
    take your air filter lid and filter out and and try to ride youe bike down the road wide open. It will prolly start spitting and spuddering over about half throttle. It will make a difference..
    Mar 2015
    Ynys Môn
    4,571
    I find myself in the curious position of both agreeing with Fred, and agreeing with Admiral — though Fred did temporarily make my brain hurt with “stimulate more fuel to be sucked through various fuel circuits resulting in same stochiometric ratios, just at a higher c.f.m” — although he did redeem himself with “the ratio is mechanically fixed by the physical geometry of the various fuel orifices all driven by suction caused by the air flow according to the Bernoulli principle” — that at least I could (barely) understand.
    Fred — yes — your theory works in “principle”
    And yet I can “see” how Admiral’s theory would work in practice — otherwise why would we need to re-jet when putting K&N type filters on there ?
    If you have a finite maximum fuel flow (determined by the main jet size), then increase the air-flow (the holes) - or more realistically “reduce the resistance to air flow” — then that fuel flow still remains finite.
    It may not apply until the main jet is “full on” — but you can see where my thinking is coming from ……
    (That’ll teach the pair of you to give me a headache) …….
    - Hidden Content
  1. air box with holes and no filter
    By joeys60 in forum Technical Help
    Last Post: 01-28-2015, 01:56 PM
  2. Oil filter with no holes, how bad could it be?
    By Lyterx in forum Technical Help
    Last Post: 06-30-2014, 07:03 AM
  3. Oil Filter With Two Holes
    By Avi Kwame in forum Technical Help
    Last Post: 01-26-2014, 04:14 PM
  4. Old airbox boot.. new airbox boot.. still too short
    By silverhead in forum Technical Help
    Last Post: 05-10-2013, 12:36 AM
  5. Punching holes in Ricochet
    By Adam-n-nevada in forum Performance and Customization
    Last Post: 06-27-2012, 03:59 PM
