Number of TW's sold in the U.S. annually? Number imported? - Page 3
Page 3 of 3 FirstFirst 123
Results 21 to 23 of 23
Like Tree42Likes
Thread: Number of TW's sold in the U.S. annually? Number imported?
  1. #21
    18,833
    If it is important then one can always go get the answer oneself.
    Start with a phone call to Yamaha MotorCompany:1 (800) 962-7926
    TW-Brian likes this.
  2. #22
    Jan 2017
    Southern Nevada
    1,077
    There was a lot to like about my V7II, but it was VERY cold natured and behaved cold on a warm restart for about 1/2 a minute.
    Possibly an issue with heated O2 sensors warming up...just a guess.
    This was my report on the Sportsgter forum, almost two years ago.
    540 mile / 17 day report:
    1. Love the low end torque...and I am already accustomed to H-D Sportsters.
    2. Love the 5.55 gallon fuel tank
    3. Love the light weight (436#)
    4. Love accessibility for checking spark plugs
    5. Love the black powder coated alloy wheels (does not show grime and I really appreciate tubeless tires)
    6. Love key access to seat removal (two bolts on Bonneville and one bolt on Sportsters)
    7. Love the seat height...not too low...not to high
    8. Love the storage under the seat for a small tool bag, spare fuses, spare spark plugs, 6x9 zip lock bag of schematics, etc.
    9. Love readability of the gauges...although the numbers could be a tad bigger for 70 year old eyes
    10. Love the ground clearance and lean angle capabilities
    11. Love the shaft drive
    12. Air filter (AP8104924) is inexpensive at $8 - $9
    13. Spark plugs (NGK CPR8EB-9) can be ordered from O'Reilly's for $4.49 each
    14. Yuasa YTX14-BS battery equivalent is stocked at my local O'Reillys (ETX14), a factory filled AGM for $102.99
    15. The 3 relays (headlight on after startup, start and injectors) are the same part number (AP8224462) and are only about $7
    16. Appreciate easy access to air filter, fuses and battery, although 3 relays are under the fuel tank
    17. Most sensors (and injectors) are easy access (right head temp, oil pressure switch, engine RPM, etc), but some are not (neutral switch, TPS, coils)
    18. Seat has been comfortable for up 6 hour days, thus far; whereas both Sportsters and Bonneville seat required upgrades for more than 50 miles. Can better evaluate after a 300+ mile, 5 hour+ run to Stove Pipe Wells in Death Valley, planned for the end of March.
    19. This is the first bike which may remain absolutely stock, other than a Dart Marlin flyscreen, removal of decals and stickers and LED tail/stop 1157. I added Pelican cases for side bags
    20. Only negatives are:
    Major
    A. the lean mixture, both cold start (likes 2 minutes +) and even after a "warm" start after only a few minutes shutdown, which likes almost a full minute after re-start.
    Minor
    B. a few things are crowded under the tank/between the heads (throttle body, coil, etc.)
    2014 Honda CB1100
    2018 Yamaha XT250
    2016 Moto Guzzi V7 II
    2017 Yamaha TW200
    2012 Triumph Bonneville
    2002 H-D Sportster 1200 Sport
    2003 H-D Sportster 883
    1976 Honda CB750F
    1975 Honda CB360
    1970 Yamaha CT1
    1972 Yamaha CT2
    1972 Yamaha AT2/CT2
    1970 Honda SL350
    1970 Honda CL350
    1967 Honda CL160
    1967 Honda CB160
    1962 Honda CA110
  3. #23
    Senior Member Apolloha's Avatar
    Dec 2018
    221
    Thanks! Im gonna call. Just curious. I bet all the after-market folks know these numbers.
    2017 Apollo 250
    2018 Yamaha TW200
    1978 Suzuki DR370
  1. CornShield Prototype Number 2
    By Cornelis in forum Technical Help
    Last Post: 09-02-2015, 11:34 PM
  2. chassis number and Engine number range
    By SLMaxt20 in forum Technical Help
    Last Post: 05-22-2014, 10:04 PM
  3. number of pics
    By howardgene63 in forum General Discussion
    Last Post: 12-24-2012, 11:29 PM
  4. Test Number 2
    By planefolks in forum Test Forum
    Last Post: 06-19-2011, 12:17 PM
  5. air filter part number
    Last Post: 06-18-2011, 12:59 PM
how many tw200 were sold last year
moto guzzi import numbers
