Standard vs. O ring vs. X Ring Chain
Results 1 to 10 of 13
    Senior Member Fishman393's Avatar
    Apr 2011
    Cincinnati, Ohio
    116
    I am in the process of deciding on a new set of sprockets ans chain for my TW. I have read alot of info on this forum and it seems that the o ring is the most desirable. However in researching the topic, I found this site[url="www.quality cycle.com/truth about motorcycle chains.htm"] site regarding motorcycle chains. After reading it, I am now even more confused. I am posting for for opinions. Sometimes to much information makes for a long decission process.
    Apr 2011
    Cincinnati, Ohio
    116
    Sorry about the link. If will gladly make it work if only I knew how. HELP
    Apr 2011
    Cincinnati, Ohio
    116
    Apr 2011
    Cincinnati, Ohio
    116
    Desert, SoCal
    7,369
    Apr 2011
    Cincinnati, Ohio
    116
    Thanks for the link Lizrdbrth. How did you do it so I am able next time....
    Desert, SoCal
    7,369
    Quote Originally Posted by Fishman393 View Post
    No problem. Copy and paste it from your browser window.
    In TW terms higher tensile strength is a good thing not because the massive, groundpounding horsepower of a TW leads to broken chains, but because higher tensile strength indicates better materials. Closer tolerances affect longevity with regard to chain stretch over time. Less chain stretch affects the number of new sprockets eaten by your bike over time. If these claims are true you'll be money ahead to spend the extra.
    As to the O-ring vs. X-ring thing I'm thinking the difference may be somewhat negligible. I'd buy it for the tensile strength,
    Senior Member rmartin's Avatar
    Quartzsite, AZ/ Hoopeston, IL
    392
    It is amazing at the number of people I run across that don't know how to copy and paste.
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    i have one of the d.i.d. o-ring chains that site says they won't recommend because it hasn't been updated in 10 years. the tw hasn't been updated in 10 years, so i guess they wouldn't recommend it?
    Apr 2011
    Cincinnati, Ohio
    116
    I looked and have been unable to find the "X Ring" type chain in the 428 size. As for the "o ring" chains:
    RK 428 SO 5500# Tensile strength
    EK Sroz 5300#
    DID 428 Pro V 5340#
    RK 428 MXZ non o ring 5800#
    DID 428 Standard 4280#
    I guess it comes down to time riding or time maintaining......
  1. did o-ring chain
    By howardgene63 in forum General Discussion
    Last Post: 10-17-2012, 08:37 PM
  2. New o-ring chain is on
    By goldenhtr in forum Technical Help
    Last Post: 07-31-2012, 08:35 AM
  3. what do you use on your O ring chain
    By aladdin in forum General Discussion
    Last Post: 05-30-2012, 04:48 PM
  4. DID O Ring chain
    By cdsdave in forum Technical Help
    Last Post: 04-03-2012, 05:40 AM
  5. o-ring chain
    By mrx916123 in forum General Discussion
    Last Post: 07-04-2011, 10:19 PM
beeg mxz
chain
o ring vs standard chain
o-ring vs x-ring chain
quality cycle truth about chains
sun star
tw200 o-ring chain
what is better a oil ring chain or a standard chain for yamaha tw 200
what quality are original cycle o ring chains
x ring vs o ring chains
yamaha tw200 o ring chain
yamaha tw200 o-ring chain
