What is the Strongest Rear Rack Available?
Page 1 of 7 123 ... LastLast
Results 1 to 10 of 68
Like Tree143Likes
Thread: What is the Strongest Rear Rack Available?
    Senior Member LuvNot's Avatar
    May 2015
    Hampton, VA
    927
    I realize this question is a little subjective, but I'm looking for feedback from folks who use and abuse their rear racks regularly.
    This summer when I go to Maine, I'm taking the TW as my primary go-to vehicle. But instead of towing it, the bike will be secured to the deck on the back of my old bus turned RV. Last time I used the bus to go coast-to-coast and carried a 220cc scooter. The scooter was literally craned onto the deck by strapping the handlebars and back rack (which bolted directly into the frame).
    Looking at the TW rear fender, I can't really see a way to do the same without having a pretty strong tail rack. The little one I have on there now just bolts onto the subframe and that doesn't seem strong enough.
    Obviously, there is the Cycle Rack - you all have great things to say about it. But are there other tough racks that are bolted directly to the frame and would allow me to lift the bike without fear of breaking a frame weld?
    Your advice, as always, is appreciated!
    Ledmelon likes this.
    My 2-Wheel Babies: 2017 Versys X 300 - 2006 Kawasaki Nomad 1600 - 2009 Piaggio MP3 500 - 2014 Honda Ruckus
    Hailey, ID
    3,328
    My vote would be for the CycleRack.....probably the strongest of all, and also carries the most stuff. You could also rig up a bridle of heavy nylon webbing that would go down and around the swing arm on both sides....something like a towing strap but shorter.
    joeband, goldenhtr, Peterb and 1 others like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member grewen's Avatar
    Oct 2014
    Armstrong BC
    2,388
    35.JPGI have a cycle rack on my tdub. when installing it, I welded a piece of 1" flat bar under the seat, from side frame rail to side frame rail. I also added 1" flat bar from the back of the rack to where the signal lights bolted in. now the back of the bike is strong, but even with these changes, I wouldn't use the rack for an attaching point for a crane lift. I like Rocky's idea better, then you are grabbing on to34.JPG something that was designed to carry weight
    TWilight likes this.
    Greg
    2019 honda cb500x
    2018 honda grom
    2018 suzuki dr200
    Member LittleTen's Avatar
    Dec 2015
    33 hrs southeast of LittleTommy
    93
    I'll second that....
    Another vote for Cyclerack also, but as a member of the CBOA, this x-cargo arraingment is what I'll be stuck with for a while longer...20160312_103628.jpg
    LuvNot and Hambone like this.
    All Hail the Sons of Arthritis!
    May 2015
    Hampton, VA
    927
    <face-palm> Doh! What a ditz I feel like right now. Of course!!! I could just strap onto the passenger peg brackets.
    That's what I get for becoming fixated on one-way, linear thinking.
    Thanks Rocky! You just saved me some money better spent on actual vacation
    Senior Member mrlmd's Avatar
    1,153
    I pick up my Suzuki S50 as well as the TW200 with a rope or sling through the wheels. It works fine and you can easily rig up a small spreader bar out of a 2X4 to keep the ropes or straps away from the fenders if you are worried about them. Or run the lines down around the bottom of the bike. You don't need a rack to pick it up.
    Hailey, ID
    3,328
    Quote Originally Posted by LuvNot View Post
    .... I could just strap onto the passenger peg brackets.
    Even better, then the strap would not contact the seat or plastic. Or maybe it would....maybe something like this would prevent that:
    Easy to mimic with a piece of wood. I'm assuming you will be removing or de-tensioning the straps when tying down the bike to the rack.
    Cool bus!!!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member GaryL's Avatar
    Jun 2013
    Forestburgh, NY
    8,036
    The weakest part of the CR rack is the flat strap under the seat that the rack attaches to and not the rack itself. Before I bought my MC lift jack I always used the CR with a block and tackle attached to a beam in my garage and attached directly to the CR just in front of the side welded J shaped tubes. Keep in mind the two bolts are just standard 6 MM bolts and that cross brace on the frame is just a shaped, thin strap with relatively poor welds to begin with that often break. Probably fine for any down weight we put on our racks but not so good to use the rack as a hoist point unless you beef it up from below. My buddy Bucknutz is strong as an Ox and has lifted the back of my bike many times from the back of the CR.
    1987 Yamaha BW350 Big Wheel
    May 2015
    Hampton, VA
    927
    Cool bus!!!
    Rocky, that sling is similar to what I used on the handlebars of the scooter, with a final single point on the rear rack.
    Basically, I winched the scooter up into place, chocked the front wheel, strapped down the handlebars using regular ratchets, wrapped the rear wheel to keep it from bouncing, then removed the lift straps, secured the crane, and moved on to the next city. It took a while, and could be challenging when the campground parking space wasn't on level ground, but ultimately, it was well worth the effort. I got to ride a lot of pretty country (Black Hills, Devil's Tower, Salt Lake City area, Lake Tahoe, the outskirts of San Diego, then up and down the Dragon's Tail in Maggie Valley a couple dozen times).
    As soon as my refund check comes in, I start the bus prep, part of which includes checking out the crane. I will have to replace the wire (original bare wires is rusted into a nasty mess) and will do a couple of trial lift and fits to make sure the TW works as well as the scooter did. The trip is still almost six months out, but time flies and there's lots to do.
    Thanks for all your advice, gang! I really appreciate the excellent feedback.
    Gerry likes this.
    Senior Member Ski Pro 3's Avatar
    May 2014
    El Dorado, California
    798
    It is hard to believe the denial of cycle rack owners. The only rack I've ever heard of breaking on the forum is the cycle rack brand rack. And not just once, but several times. Over and over again. Not because of crashes either, just to carry a load and ride, the things break.
    Not only are they oversized and ugly, they break at the drop of a hat. I'd advise to stay clear of the cycle rack.
    The bear slayer!
  1. Rear Rack?
    By Darth in forum General Discussion
    Last Post: 10-09-2015, 01:54 PM
  2. Rear Rack
    By stevenmichael in forum Performance and Customization
    Last Post: 03-20-2015, 08:59 AM
  3. Replies: 5
    Last Post: 10-05-2012, 05:31 PM
  4. WTB Rear Rack and Rear Turn Signals
    By philp38 in forum TW200 Classifieds
    Last Post: 02-17-2012, 11:27 AM
  5. looking for a Cycle Rack rear tw rack
    By bigrob in forum TW200 Classifieds
    Last Post: 01-31-2012, 05:43 PM
back rack for tw200
rack
racks
strongest tw200 rack
tw200 cycle rack too big
tw200 cyclerack mounting points
