Cycleracks Installation
Results 1 to 10 of 10
    Junior Member royalman's Avatar
    May 2011
    Virginia
    10
    Hello all---a newbie and first time poster here:
    Newbie in that I've waited my entire life to get on two wheels---my wife and I have come to a mutual agreement that this desire just CANNOT be stifled, and that the best way is to get out in these beautiful Appalachian Mountains here in Virginia and ride some trails!! Can't think of a better bike to do it on than the T-Dub. I will be buying late year or early next year once I have some cash in hand.
    On the post: I've seen many discussions here as to the best rack system. From what I've seen, it certainly looks as though the Cycleracks rack has the winning vote. My question is whether the installation is straightforward, and if any necessary hardware is included. The Cycleracks site says nothing of installation, and as I'm planning my perfect steed, these are the questions I need to know the answers to!
    I would appreciate any tidbits, no matter how brief, as to the ease or experience with installation regarding this rack.
    Many thanks!
    Member bend42's Avatar
    86
    Everything is included and it is delightfully straightforward.
    Terrific rack!
    John
    May 2011
    Virginia
    10
    Wow, great to hear. Thanks very much for that response! Can't wait to land that T-dub!!
    Member StevieP's Avatar
    Irwin, PA
    86
    royalman,
    cyclerack's are the best. I bought mine used off of a member so nothing in the line of directions really came with it but it was easy to install. Only thing is, if you plan on keeping your rear footpegs (which is where the cyclerack bolts in at) you're gonna need a longer bolt, which you can pick up at yamaha dealer. good luck on your hunt for the TW....
    Ephrata, WA
    1,125
    You'll have to remove your seat and then remove two other bolts under the seat. You use these bolts to secure the rack under the seat. Two longer bolts are included to replace the ones on your passenger pegs. You may need to tweak the rack a bit to get it to line up to the passenger peg holes. The rack is made correctly, its just a tight fit. Let us know if you need help, I'll take some pictures for you if you want.
    1990 TW200
    Senior Member NumberThree's Avatar
    124
    One good tip is to attach the seat bolts first...then the other bolts for the rack....
    Ephrata, WA
    1,125
    Quote Originally Posted by NumberThree View Post
    +1
    1990 TW200
    actually, a good tip is to just get the bolts under the seat started about 4 turns in, then line up and install the bolts at the foot pegs. Once all the bolts are started, easier to do with things flopping around, run the smaller bolts snug, then the bigger bolts, then tighten the smaller bolts, then tighten the bigger bolts. It is amazing how sometimes the order bolts are installed and tightened makes a big difference.
    124
    Excellent point! I was trying to remember the struggle I had installing the rack a couple of years ago; it was tightening things before all the bolts were in.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,516
    Alittle tight, is a massive understatement.I've read the various posts on this racks install and tried all the different install techniques....this morning I spent about an hour wrestling this SOB prior to going off to work....still not installed!. Had the cyclerack,rack on a different make of bike a few years ago....pretty easy install;on this TW,it's a major PIA.One more attempt when I get home at the continued install,if this continues to be a problem,back to Idaho it goes!!!!!!!!!.
  1. Tusk D-Flex Handguard Installation
    By SpudRider in forum General Discussion
    Last Post: 03-10-2019, 08:56 AM
  2. Chain Seal, Guard installation
    By mkriley in forum Technical Write-Ups
    Last Post: 05-27-2013, 12:00 AM
  3. MSR Billet Bar Ends Installation?
    By hoginthebog in forum Technical Help
    Last Post: 04-23-2013, 08:31 PM
  4. Cotter Pin Installation Video
    By sorethumb in forum Technical Help
    Last Post: 09-23-2011, 09:14 PM
  5. Rear Brake Shoes Installation
    By thumper in forum Technical Help
    Last Post: 10-30-2010, 09:29 AM
cyclerack tw install video
cycleracks instalation video
cycleracks tw200 install
cycleracks tw200 problems
how to install cyclerack
how to install cyclerack rack
how to install cycleracks
tw200 cycle rack installation
tw200 cyclerack
tw200 front cyclerack installation
tw200 installing cyclerack
tw200rearrackinstallvideos
