street or dirt tires?
Results 1 to 7 of 7
Like Tree7Likes
  • 1 Post By joeband
  • 3 Post By bananachunks
  • 3 Post By Xracer
Thread: street or dirt tires?
    Member MOTOMAX on YOUTUBE's Avatar
    Jan 2016
    49
    my tires are just about done (stock) any suggestions for tires? i was looking into street tires just for the long mileage...
    Nov 2011
    norcal nutjob
    3,309
    bananachunks can weigh in... he loves his shoes.
    bananachunks likes this.
    Senior Member jb882's Avatar
    Aug 2013
    1,375
    It depends on what you are doing. If you have any intentions of going on dirt i would get dirt tires. On a TW they last plenty long so you should have no worries, one of my TW's has 17k miles on the clock and i changed the stock tires out at 15k which is a very long time for a motorcycle tire, could have gone longer too but dry rot was setting in on the rear. Compare that to my Ducati that needs new rubber every 3-5k miles or 2-3 times every summer depending on how much i ride it....
    May 2014
    Yooper, MI
    1,510
    I'd second (or is this third) dirt tires, but then I am somewhat biased. As you have stated the only reason not to run knobbies on the pavement is tire life. They do perform quite adequately on pavement. However if/when you go off road with street tires they suck at 3600 psi.
    Senior Member bananachunks's Avatar
    Jul 2013
    San Francisco
    1,101
    <3 my Shinko 428s. They're right at about 9000mi and just now starting to show wear. I'm probably 98/2 as far as street/dirt goes, and they've impressed the heck out of me off-road. This last weekend at Metcalf park is the first time I've ever lost traction in the rear, but two other stock TWs lost traction in the same spot, so I'm not counting it as official.
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,765
    Depends on where you ride. If like me your Dub spends 99 percent of its time on the street then spoon on a set of 203/204's and rail the Dragon.
    littletommy, ldjbuff and DaveF like this.
    Senior Member Tinybear's Avatar
    Apr 2014
    SW Ontario
    254
    For me the only reason I have a TW is to explore off road. The fact that I can use it for commuting is a bonus.
    So one more vote for dirt tires.
    Besides tires for these things are cheap and last a good while.
    2017 Suzuki V-Strom 650 XT
    2010 Yamaha TW200
    2016 Polaris Sportsman 450 HO
    2005 Yamaha Bruin 350 4x4
  1. street tires
    By ghagen in forum TW200 Classifieds
    Last Post: 06-16-2014, 03:09 PM
  2. Best T-Dub Tire Set up For 70% Street 30% Dirt ?
    By magyarmoto in forum General Discussion
    Last Post: 10-25-2013, 07:58 AM
  3. Which street tires?
    By frehley76 in forum General Discussion
    Last Post: 10-09-2013, 01:08 PM
  4. Cost to re-street a dirt only TW?
    Last Post: 10-25-2012, 05:50 PM
  5. Street Tires
    By Caribbean in forum General Discussion
    Last Post: 03-04-2011, 06:02 PM
