Noob introduction and a few questions
Results 1 to 10 of 17
Like Tree45Likes
Thread: Noob introduction and a few questions
    Junior Member Nutfarmer's Avatar
    Apr 2016
    Red Bluff, CA USA
    9
    Hello,
    I just bought a new to me 2009 TW today and had my first ride. What a hoot! My other bike is a Vstrom 1000 so it's a bit of an adjustment. I plan to ride the TW mostly on my farm and trails on our property and I am also hoping to get the wife riding and licensed on it. For those who want to know, it has 3800 miles and I got it for $2800.
    The bike didn't come with a manual and I have a couple of quick questions:
    - The clutch only engages when the lever is almost fully extended. I fiddled with the adjustment at the clutch lever but it didn't seem to change anything. Is this normal and should I be adjusting it down where it goes into the gear box?
    - I use Rotella T6 5-40 wt. fully synthetic oil in my vstrom. Is it okay to use this oil in the Tdub? I live in Red Bluff CA, where it gets hot as hell and not terribly cold.
    - Any suggestions on where to get a manual?
    Looks like a terrific forum here and I look forward to being a part of it!
    Nutfarmer
    Mel, Joemama and TWilight like this.
    May 2014
    Yooper, MI
    1,510
    The clutch is normal and is a point of great discussion. Juan would have thought that Yamaha would have done something about it by now, but alas, no. You can buy after market springs and adjust the clutch under the side cover to make it feel more"normal".
    Oil. I know nothing of oil. Which oil is best? Is that your question? I don't think it's ever been brought up here....
    Manuals are posted here;
    https://tw200forum.com/forum/technica...r-manuals.html
    littletommy and TWilight like this.
    Senior Member Rhodetrip's Avatar
    Aug 2010
    Out wandering around
    1,930
    Quote Originally Posted by Devils Advocate View Post
    Juan would have thought that Yamaha would have done something about it by now...
    Juan who?
    "Me and Mrs Trip, we got a thing going on"... an on-going adventure...
    "When Piggies Fly" ...Me & Mrs Trip Cross the Pond
    "Take the Puppy to the Beach"...a dirt route across southern New England
    Latest Spotwalla: Hidden Content
    Apr 2016
    Red Bluff, CA USA
    9
    Thank you for the service manual! And good to know the clutch is normal for the TW.
    Regarding the oil, I just want to know if the Rotella T6 is ok for the bike (not necesssary the best). From other forums, I know oil is a touchy subject!
    TWilight likes this.
    May 2014
    Yooper, MI
    1,510
    I think that would be just fine for your TW. As sophisticated and high tech as it is I don't think that the oil it uses is as much of an issue compared to which blinker fluid or high speed bumper bearings you use.
    TWilight, grewen and saabbug like this.
    Hailey, ID
    3,341
    Quote Originally Posted by Nutfarmer View Post
    - I use Rotella T6 5-40 wt. fully synthetic oil in my vstrom. Is it okay to use this oil in the Tdub? I live in Red Bluff CA, where it gets hot as hell and not terribly cold. ....
    As long as that Rotella is certified for use in wet clutch machines you should be fine. 10W40 might be a little better. When it's super hot you might want to go to 20W50, but only if you do a lot of hill climbing when it's 110 out. 5W40 is fine for moderate use.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Apr 2016
    Red Bluff, CA USA
    9
    Got the oil changed and chain lubed. Then took off the stickers - the tank sticker was a bugger!
    Thanks for the help.
    Mar 2012
    Boonville, No.-Calif.
    1,357
    Quote Originally Posted by TWilight View Post
    Be aware that living in Red Bluff....you are required....required I say...to join the NorCal Nutjobs.........and being a Nutfarmer, you have a double qualification.
    Welcome! TWlight is right! Keep an eye out for our next ride! m.
    May 2013
    Groton, NY
    2,663
    Greetings from NY!
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Nov 2011
    norcal nutjob
    3,313
    welcome! we've had some great rides in the nor cal area... stay tuned for the next one.
    https://tw200forum.com/forum/trails-o...-300-a-12.html
    https://tw200forum.com/forum/trails-o...ed-jan-17.html
    Fred and TWilight like this.
  1. Noob saying Hi
    By MikeJnz3 in forum General Discussion
    Last Post: 06-02-2013, 08:36 PM
  2. Noob here...
    By respond2us in forum General Discussion
    Last Post: 02-25-2013, 06:42 PM
  3. Another noob
    By Tirebiter in forum General Discussion
    Last Post: 03-07-2011, 11:33 AM
  4. Possible noob here, couple of questions
    By Pigdog in forum General Discussion
    Last Post: 09-30-2010, 07:45 PM
  5. Noob first ride
    By Gadget Man in forum General Discussion
    Last Post: 09-14-2010, 11:54 PM
