Trailer Upgrade!
Results 1 to 9 of 9
Like Tree13Likes
  • 4 Post By SickPuppy76
  • 3 Post By ejfranz
  • 1 Post By ejfranz
  • 4 Post By Fred
  • 1 Post By old w/??
Thread: Trailer Upgrade!
    Senior Member SickPuppy76's Avatar
    Glenville, NY The Vampire State
    667
    Trailer Upgrade!
    I upgraded my 5x8 trailer today with a 3/4" plywood deck and added a wheel chock to haul the TW. I have it loaded and strapped down, and have the front shocks compressed pretty far, as they are soft. Will this create any issues for me? Trailer.jpg
    "SickPuppy76"
    Greg from Glenville
    2014 TW200 rear Cyclerack with bag supports and Versapack saddlebags, upgraded foot pegs, Mad Dog seat cover
    2014 Nissan Pathfinder 4WD
    2005 Buick Rainier AWD
    2001 Bass Tracker Pro Team 185XT
    Old Town Trip10 Angler Kayak
    Feb 2015
    Maple Ridge, BC, Canada
    1,543
    With the choke you should not have to compress your front shocks more than 1/2 way. You can buy or make a stop to go between your top bracket and the wheel to prevent the shocks from being compressed too much.
    667
    The choke?
    "SickPuppy76"
    Greg from Glenville
    Feb 2015
    1,543
    Auto correct
    SickPuppy76 likes this.
    18,702
    Chock was the intend word. A scrap 4 or 5 inch piece of 4x4 might make a good stop as ejfranz suggests. Placed between fender and lower triple clamp allows your tie downs to compress suspension against the wood taking up any slop without worry of blowing out fork seals.
    Apr 2014
    979
    One thing you can try is using tie-down extensions. I have used them making a double wrap around the bottom of the fork rubbers above the fender mount and tie down from there. No fork compression. You can tie down from the bar area slightly compressing the forks also; or just to the sides to keep the upper area from torquing against the lower tie-downs. I also do a tie-down wrap around the front tire and wheel chock.
    Smitty Blackstone likes this.
    667
    Thanks for all the input. I trailer it with it compressed almost all the way with no issues but will utilize some of these ideas next time
    "SickPuppy76"
    Greg from Glenville
    18,702
    Certainly having the front tie-downs extending as horizontal as possible will reduce need to compress forks for a stable haul (i.e. attach tie-downs to the trailer's raised side rails as opposed to the trailer floor).
    Does anyone have first hand experience with motorcycle wheel chocks that actually support the front of a TW securely?
    667
    I just bought a cheap wheel chock from my local place. They had two widths, I got the wider one. Worked great.
    "SickPuppy76"
    Greg from Glenville
  1. My bicycle trailer/ TW pan trailer
    By thelazyblack fox in forum Trails, Off-road, and Adventure Riding
    Last Post: 04-10-2016, 12:55 PM
  2. Tw 125 upgrade
    By Mattymarshall in forum Performance and Customization
    Last Post: 03-23-2016, 12:29 PM
  3. Trailer / Camper Upgrade
    By M C Toyer in forum General Discussion
    Last Post: 11-24-2015, 06:31 PM
  4. Upgrade to the ole tw
    By andy10889 in forum Other Bikes
    Last Post: 11-26-2014, 02:41 PM
  5. Cam upgrade
    By Skyking in forum Performance and Customization
    Last Post: 01-07-2012, 01:39 PM
