Fast question...
Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Like Tree96Likes
Thread: Fast question...
    Senior Member akalogan's Avatar
    Jan 2016
    3 hours south of LittleTommy
    425
    Fast question...
    Is 185 miles on the clock too soon to take at Highway speeds? I really want an extended run at 60 to see what the little Dub is like... Too soon??
    18,719
    Fast answer... I would not fear a brief 60 mph test but would avoid "extended" running at high rpm, or other high temperature or high loads on the engine for first 600 miles.
    Jan 2016
    425
    5ish miles ok?
    Senior Member 1911garand's Avatar
    Nov 2015
    Great White North
    715
    Nope, 185 miles is not too soon - Run it, it will be fine.
    littletommy and jtomelliott49 like this.
    Yamaha - 1992 TW200
    BMW - 1995 R1100GS
    May 2013
    Groton, NY
    2,663
    On the way home from the dealer, I held it wide open for about a mile. 7,800 miles on it now, no apparent damage. I figured, what the heck, it's under warranty.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member Beeline's Avatar
    Sep 2014
    Arcata, CA
    230
    have you changed your oil and cleaned the filter yet? I know the manual says something like 500 for first change but some TW's have a bit of metal shavings from the factory. No big deal but good to get it out of the engine before stressing it.
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    Quote Originally Posted by akalogan View Post
    If you do, let it cool down slow. Don't just run it HARD then shut it off and park.
    18,719
    Any debris trapped on a filter has already been caught and removed from the fluid stream. As such it will do no further harm unless in the highly unlikely event that there is so much debris that it impedes flow rate. Similarly factory oil with only 180+ miles will not have suffered much thermal break-down, acid build-up or acquired much micro particulates. That said there is nothing wrong with an early oil change from whatever oil came in the bike to a known quality product.
    Spokane, Washington
    17,289
    Quote Originally Posted by scotti158 View Post
    bye bye 20,000 miles later on...
    1st John 1:9
    John 3:16
    John 3:17
    Hailey, ID
    3,341
    Is 185 miles on the clock too soon to take at Highway speeds? ...
    Depends what you mean by highway speeds....with stock gearing going up to 60 should not cause issues if only for five minutes or so. Running any steady RPM for a long while is not the best form of break-in...but the engine doesn't know if it's going 6 or 60, and the best cooling will occur at 60 in 5th. Go for it! Just don't go down a long hill at 75!
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
  1. Its not fast, but....
    By JSwanson in forum General Discussion
    Last Post: 05-13-2016, 09:01 AM
  2. Fast Boat
    By arrowsmith in forum Off-Topic
    Last Post: 12-04-2015, 08:17 AM
  3. How Fast Can I Go?
    By Tipsy Wombat in forum General Discussion
    Last Post: 06-25-2013, 10:29 PM
  4. Fast Tdub
    By stephenmarklay in forum General Discussion
    Last Post: 03-30-2013, 03:29 PM
  5. Going too fast? :(
    By Drapes in forum General Discussion
    Last Post: 08-01-2012, 12:56 PM
