Luck day! The colors even match.
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Like Tree103Likes
Thread: Luck day! The colors even match.
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    I got way lucky today, picked up this 1999 TTR-225 for $200.00, unmolested, very low mileage. Original sprocket, not even worn a little and the exaust port is extremely clean. All screw heads are like new even, never turned..
    and this with ZERO! Zero! Miles a 1990 TW200 engine from a dealer who had it on the shelf. He pulled out of the chassis right off the showroom floor way back when and used the chassis for a project. It's been in the back of his shop on a shelf ever since.
    yay!
    Fred, littletommy, dette and 11 others like this.
    Spokane, Washington
    17,283
    Quote Originally Posted by JerseyJeeper View Post
    yay!
    Nice...
    1st John 1:9
    John 3:16
    John 3:17
    Mar 2011
    3,880
    They're on the way to me, it's like Christmas! 6 speed 225!
    Nov 2011
    norcal nutjob
    3,309
    nice. you will enjoy it
    littletommy and JerseyJeeper like this.
    Mar 2012
    Boonville, No.-Calif.
    1,357
    OOOHHHHH!!!!! Lucky!!! Now comes the hard part, what to do... m.
    Mar 2011
    3,880
    Quote Originally Posted by mhomadness View Post
    First step is to buy another TW! I need one to start building so I can keep riding!. I have a line on one but I need to get a real close look at this new 225 and make sure it's as good on the inside as it is on the outside. I also need to get number one daughter a car for college.. This will be a winter build, I'll spend summer and fall collecting all the little pieces.
    Senior Member pred's Avatar
    Mar 2016
    Philadelphia and Pittsburgh pa
    545
    Great find.
    Will the 225 bolt right in?
    littletommy, akalogan and Darth like this.
    Mar 2011
    3,880
    Quote Originally Posted by pred View Post
    Great find.
    Yes but the sprocket shaft needs to be swapped with a modified one from a TW (new groove cut and a spacer made)
    225 shafts are shorter and don't extend into the side cover oil fed bearing like on a TW. So you need the TW side cover too and the proper stator/ etc and flywheel.
    Mar 2016
    545
    And what might you do with your older TW engines?
    I may be in Wharton this weekend if I don't need to be in Pittsburgh as usual,
    It would be my first time on two wheels there since I was there on my Honda CB750,
    Should be an interesting trip.
    Senior Member lbxr's Avatar
    Jan 2015
    Gold Beach Oregon
    338
  1. luck of the draw.
    By ZDR1 in forum Off-Topic
    Last Post: 11-26-2015, 01:44 AM
  2. wish me luck!
    By SickPuppy76 in forum Off-Topic
    Last Post: 05-14-2015, 05:53 AM
  3. Wife is at MSF course today wish her luck!
    By Holdnon72 in forum General Discussion
    Last Post: 05-18-2014, 07:45 PM
  4. mix and match?
    By Turd_Ferguson in forum Technical Help
    Last Post: 03-08-2013, 08:15 PM
  5. What year plastics match ???
    By KIC in forum General Discussion
    Last Post: 11-16-2011, 09:50 PM
