Fuel Filter for TW200?
Results 1 to 8 of 8
    Junior Member kiloforce's Avatar
    Aug 2010
    Utah
    12
    I have seen several suggestions to install a fuel filter, as the TW200 does not come with one. Which fuel filter is recommended, and where is the best location to install the filter to?
    Moderator vuldub's Avatar
    Aug 2010
    Calgary, AB Canada
    652
    How's this:
    Inline Fuel Filter - TW200
    You can buy the filter at any autopart store - you also don't need to clamp it as its not pressurized.
    Regards...Wes
    Aug 2010
    Utah
    12
    Are the forums in the process of being rebuilt?
    Through Google I found the following thread (https://tw200forum.com/forums/89801/ShowPost.aspx) which appears to be using a separate forum system. The photos links are all broken. By chance, does someone have a archived copy of this post with pictures?
    Aug 2010
    Utah
    12
    Thanks vuldub, that is exactly what I was looking for.
    Senior Member JS5owner's Avatar
    Palm Springs / Desert Hot Springs
    308
    Quote Originally Posted by Kilo Force View Post
    The petcock has a very fine micro screen on it... However I did put a 90 degree clear filter on as well.
    2007 TW "Muley": Cyclerack rear, 55 tooth rear sprocket, Duro Power Grip & Shinko SR241, Clarke tank, Ricochet bash plate, Mule hitch pin quick seat removal, Trail Tech Vapor w/ Dashboard, hardwired Garmin 60csx & 205w, 12vdc adaptor, independent high beam off/on and signal beeper, modified seat.
    2000 Yamaha V-star 650 Custom - [sold]
    2009 Yamaha WR250R - "Willie Boy" the slimmer faster brother of my Muley.
    2009 Hidden Content . Wow, what fun on the highway!
    Member dawgs's Avatar
    Aug 2010
    64
    I have worried about a fuel filter for the past 30K miles on my 07' TW.
    I am still worried but not near as much as I was in the first THIRTY THOUSAND MILES without one!
    In days gone past, bikes fuel systems stopped up because of impurities, solids in the fuel. We called it dirt. We had a bowls on the bikes in those days and poured out the solids that accumulated in them on a regular basis.
    I'm not saying not to add a fuel filter but i don't have one and haven't needed one in the past 30K miles. If you have an extra free one send it to me and I will stick it on my bike. If I go to south of the border, I would add one but then I would add other things as well.
    Senior Member JarrodWeaver's Avatar
    Austin, Texas
    112
    +1 for JS5 and dawgs. The petcock has a good filter installed inside your tank. You can't over-filter gas so installing another won't hurt, but don't be concerned becasue you don't have a secondary unit installed.
    Aug 2010
    64
    Quote Originally Posted by JS5owner View Post
    I didn't know there was a screen in the pet cock. I will check it to see if it needs cleaning.
  1. Fuel Filter
    By Retrofit in forum Off-Topic
    Last Post: 08-20-2012, 06:11 PM
  2. fuel filter 90 degree
    By RingSteel in forum General Discussion
    Last Post: 04-13-2012, 10:45 PM
  3. fuel filter
    Last Post: 01-08-2012, 04:05 PM
  4. External Fuel Filter
    By Stromper in forum Technical Help
    Last Post: 11-06-2011, 12:14 PM
  5. fuel filter upgrade
    By layne in forum Performance and Customization
    Last Post: 02-24-2011, 08:36 PM
changing the fuel filter on yamaha 200
does tw200 have a fuel filter
fuel filter tw200
install fuel filter
replacement fuel tank for yamaha tw
tw-200 fuel filter
tw200 fuel filter
tw200 fuel filter location
where is the fuel filter on a 2023 yamaha tw200
which fuel filter
yamaha tw200 fuel filter
yamaha tw200 plugged fuel screen
