Tire questions ??
Results 1 to 6 of 6
Like Tree15Likes
  • 1 Post By RikR
  • 2 Post By scotti158
  • 3 Post By JerseyJeeper
  • 3 Post By elime
  • 3 Post By Kasky
Thread: Tire questions ??
    Member RikR's Avatar
    Aug 2013
    Vancouver Washington & Yuma Arizona
    71
    Tire questions ??
    What pressure are you running in the sand or loose dirt
    Are these tubeless tires (2016 model)
    Thanks
    littletommy likes this.
    May 2013
    Groton, NY
    2,663
    Never ridden in sand, just lots of mud. I run 8-10 psi in the rear off road. I have a Shinko 244 on the front and have that at 22 psi, all terrains. Tube tires, not tubeless.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Mar 2011
    NJ Shore / Pine Barrens
    3,880
    I run 18lb in the 241 in the sand, mud and on the road. Although I hate mud just based on having to clean it
    For me 18lb is fine for the front tire, in fact great, for the riding I do which is a daily (try to ride every day) mix of asphalt road at 55+MPH and Sand Roads (2-3" loose stuff) @ 5 to 40 MPH and then jaunts in deep sand (6"+) at whatever speed I can keep it on two wheels which with the 241 is now not a concern at all. I used to fear for my life when the stock tire was on there. I really can't say enough about this tire being a major improvement over stock. If I was in the deep stuff for any long period of time I would lower the pressure more but i'm in and out of it thankfully.
    As far as the rear tire I have not settled on a figure yet and won't do so until my new works performance shock is mounted. I'm hoping it comes today that would be a great fathers day!
    I now carry a mini compressor with me so I can tweak it trying to find what works best in the back but with a new shock all the metrics may change, we'll see....
    Quote Originally Posted by TWilight View Post
    As Scotti has already said, these are TUBE type tires...not tubeless.
    In the "sand"...I run 8 psi on the rear tire, and 13 psi on my front tire, which is a Shinko 241 Trials tire.
    Yo, Scotti, that 22 psi in the front tire is quite a bit of air pressure. Does that work for you off-road or in the mud ?
    When not riding in the "sand", I generally run 15-18 in my front tire...but never above 18. We all have our preferences.
    May 2013
    Groton, NY
    2,663
    If I go much lower in the front, it seems to wander all over the trails. I'm thinking the knobs must be deflecting a little more with the lower tire pressure giving it that "wandering" feel.
    2013 Yamaha TW200
    1996 Yamaha TW200
    6,975
    32 psi in my Heidenau front tire. 32 psi for asphalt, dirt, sand, rocks, etc. 99% of my riding is on paved roads. Less than 32 psi and the angle wear of the knobs is accelerated. I also emphasize the use of the back brake for the same reason.
    Somewhere around 14K to 15K miles on the tire and it looks like it will last a good while longer.
    Senior Member Kasky's Avatar
    May 2016
    118
  1. Tire Change Questions??
    By Mystic Explorer in forum Performance and Customization
    Last Post: 09-22-2013, 10:47 AM
  2. Tire Pressure Questions
    By RikR in forum Technical Help
    Last Post: 08-10-2013, 04:20 PM
  3. More tire questions
    By johjon in forum General Discussion
    Last Post: 03-12-2013, 09:10 PM
  4. Tire to rim alignment and balancing questions
    By Turwilliger in forum Technical Help
    Last Post: 12-20-2011, 09:36 AM
  5. Tire questions
    By harleyjoe43 in forum Technical Help
    Last Post: 11-27-2010, 05:33 PM
