Smaller rear sprocket, How small?
Results 1 to 10 of 13
    Member motorhead's Avatar
    May 2011
    46
    I am a NEW, OLD guy. I am new to the TW200 as I just traded a nice Honda Trail 90 and some cash for my 2006 TW200. I have been around motorcycles, mainly Honda and Triumph (pre 1970's)for about 45 years.
    Anyhow...
    The TW200 has a 50 tooth rear sprocket on it as stock. I have found a 44 tooth rear sprocket. Is this 44 tooth going to be too high? My 1967 Triumph 200cc Tiger cub was low geared on top end and I want with a smaller rear and it worked out good.
    I am 225lbs and the bike will be mainly used on the street. Thanks for any comments.
    866
    Quote Originally Posted by motorhead View Post
    Anyhow...
    44 is too high IMHO. I prefer the stock 50, but I ride 50/50. After reading this forum the consensus seems to be a 14/47 if you're doing mostly street.
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    i have a 45 tooth rear with the stock (14t) front. i ride only on the street. i swapped mine out after just a few days of riding because i hated the stock gearing. i am, and have been, happy with the 45t rear for over 6k miles now.
    Mar 2011
    Gobles, michigan
    1,826
    My wife and I have the 47-14 combo..... We ride 90% road.. We do like this combo.. It gives you a 1st gear that can really be used. OMM.
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    Too small I have a 47 rear sprocket, it's better in the lower gears but won't pull the top gear, I'm going back to 50.
    Member StevieP's Avatar
    Irwin, PA
    86
    I have a 44 tooth rear and ride 99% street, don't have any problems with it. I'm pushing close to 90 mpg. First gear is still pretty low, pop it into 2nd gear before ya even know it. It's workin' out pretty good for me....
    May 2011
    46
    Quote Originally Posted by 805gregg View Post
    Does it power out in fifth? Is the "805" in your forum name your area code? If so,I live in the same code. How many miles on your 47 tooth sprocket? Is it the 6 mounting hole style and if you change back, you want to sell the 47T?
    Senior Member shocker's Avatar
    Orange Park, Florida
    164
    Rear sprocker swap is not too difficult and if you already have a 44 I would suggest trying it out to see if you like it better. You may want a 47, or 45, or even the 50 but you should decide that. I have a 45 rear, ride 99% street, and feel this is the right one for me. Gearing change is popular on the TW.
    7,000
    I have dual rear sprockets -- 45t and 55t. I find the 45t is OK for flat land but when I start to cruise in the hills I like the 55t much better.
    The 45t is OK in the hills but I find long stretches of 4th gear are needed. On freeways the TW will cruise in the 65 to 70 range and I often have to go into the middle lane to pass some slow poke in the slow lane.
    With the 55t I zip up hills. Even when I have to downshift to 4th the engine handles it much better. On the freeway I am the slow poke in slow lane doing about 60 with the engine in the 8500 to 9000 rpm range. I have kept the engine at about 9000 rpm for about 45 minutes once and would do it again if necessary. It didn't seem to hurt a thing. I think the little engines likes it.
    Use the 50t sprocket on it now for a while. You'll get used to the high revs and vibration and might end up liking it.
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    I was running 15/47 out on the flat Kansas prairie. I liked that gearing for everything but headwinds. Now that I'm in Georgia with all these hills, the 15/50 is a better setup for me. But then I weigh 300 lbs.
    Stephen S.
    '07 TW200:
  1. Just got a rear sprocket (like new) $4.09 shipped
    By snakefoot in forum TW200 Classifieds
    Last Post: 04-09-2013, 06:40 PM
  2. Rear Sprocket options
    By aladdin in forum Technical Help
    Last Post: 02-27-2013, 11:50 AM
  3. Replies: 0
    Last Post: 06-14-2012, 04:13 PM
  4. 60T Rear Sprocket??
    By NHebayer in forum Technical Help
    Last Post: 06-11-2012, 12:35 PM
  5. rear sprocket
    By phazer in forum Technical Help
    Last Post: 08-23-2011, 04:23 PM
44 sprocket tw200
ag 200 with 15 45 sprocket
aluminum 46 sprocket tw200
honda s90 rear sprocket
honda tiger 200 14t sprocket
how much small is a 40 tooth sprocket from a 47 tooth
is a 44 tooth rear sprocket too small for a go kart
is a 44 tooth sprocket too small on the rear of a gokart
rear sprocket for yamaha tw200
s40 smaller rear sprocket
tw200 40 tooth
yamaha tw200 rear sprockets 40 teeth
