2006 TW200...What carburetor options?
Results 1 to 7 of 7
    Member motorhead's Avatar
    May 2011
    46
    It doesn't take me long before I get the bug to make something run better. My TW is a Calif model and the carburetor seems to surge at light throttle and low RPM. I adjusted the valves today (1950 miles) and while I had the tank off, I went for the carb. I took the black top off of the CV carb and pulled the diaphragm out to see if I could raise the needle a notch. No such luck. I made up a .015" shim to raise the needle. Man...It woke that little engine up! Still has the low speed lope, feels almost lean? Probably the CV carb,
    Does anyone have a suggestion on an older style but new slide type carb or remedies for the existing one? I thought about shortening the existing slide spring so the slide raises earlier. MIKUNI for the TW???
    Senior Member Wheelie Nelson's Avatar
    Austin, TX
    204
    have you rejetted? adjusted the pilot screw? drilled out the vacuum port in the slide?
    May 2011
    46
    No, have not re-jetted. I don't know if the Commiefornia carburetor has removable main jets or pressed in. The carburetor and main is different than the 49 state carb according to the parts fiche online.
    I will have to check the low speed air screw. So where do you drill out the vacuum port on the slide? What size drill? I saw a small brass, pressed in orifice at the top of the carb when I removed the black top cap. I DO have some pin drills. Used them alot on old VWs and Porsches.
    Desert, SoCal
    7,369
    Quote Originally Posted by motorhead View Post
    The only difference between your carb and the 49-state carb is the vent port for the canister and a RICHER jet.
    If you're loping and/or surging you've got other issues..
    1996 TW200 Edmonton, AB
    590
    Check the stickied carb tuning thread in technical, and do one thing at a time. I'd just about guarantee the idle mixture screw is set way lean.
    May 2011
    46
    Thanks guys. I'll check the idle mixture.
    May 2011
    46
    Pulled the carburetor off today and removed the block off plug for the low speed mixture screw. I opened it up about 3/4 turn and got rid of the low speed lean surge. I also put a .020 spacer under the slide needle. Runs good now.
  1. Need Gas Tank for a 2006 TW200
    By Waltonusa in forum TW200 Classifieds
    Last Post: 10-25-2012, 05:13 PM
  2. 2006 TW200 For Sale
    By mrmagoo in forum TW200 Classifieds
    Last Post: 01-17-2012, 09:08 AM
  3. Carburetor help or different carburetor options
    By dz1 in forum Technical Help
    Last Post: 05-21-2011, 09:24 PM
  4. 2006 TW200 in NC
    By getyourown in forum TW200 Classifieds
    Last Post: 11-26-2010, 02:29 PM
  5. FS: 2006 TW200
    By LuvDirt in forum TW200 Classifieds
    Last Post: 10-21-2010, 10:11 PM
2006 tw 200 carburetor
2006 yamaha 200 tw carburetor adjustment
2006 yamaha tw 200 carburetor
2006 yamaha tw200 carburator
car reactor for yamaha 200tw
carburetor for 2006 tw200
does a 2006 yamaha tw200 have a carberator
how to clean a carburater for a 2006 tw 200
tw200 carburetor options
