signal light
Results 1 to 4 of 4
Thread: signal light
    Junior Member wluebke949's Avatar
    May 2011
    Can anybody please inform me as to what I can do to make the signal light work on right hand turns.
    It works fine on the left,which is important but to comply with state laws the right should work as well.
    Please help me
    Senior Member rm_hm's Avatar
    1,619
    When you say "signal light" do you mean the little light that blinks next to the speedo when your turn signals are on, or do you mean your actual left side blinkers light(s) don't work?
    Bike year?
    Stock Indicator Bulb?
    Stock Turn Signal Bulbs?
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    I have the same problem..neither one wants to flash..front right/rear right work and stay lit till i turn it off. front left doesnt come on at all, rear left comes on.
    Desert, SoCal
    7,369
    The stock flasher unit requires the load from both bulbs in order to flash properly. If one bulb on one side is not lit then you either have a broken filament in the unlit bulb, or loose connections.
    If both bulbs are lit on one side but are not flashing odds are that your flasher unit itself is faulty.
    Some aftermarket incandescent "mini" signals don't draw enough to operate the flasher, so if you've installed munchkin signals or L.E.D. signals you'll need an electronic flasher.
    An electronic flasher will work for all types and sizes of bulbs, but the stock type flasher only works properly with the load of two 1156 or 1157 bulbs.
  1. trouble with tail light install - DRC Edge Brake Light
    Last Post: 07-13-2017, 09:36 PM
  2. WTB handle bar turn signal and light switch
    By maxvic in forum TW200 Classifieds
    Last Post: 05-25-2013, 05:31 AM
  3. inverse turning signal
    By dubstep in forum Technical Help
    Last Post: 11-13-2011, 08:48 AM
  4. WTB - Turn signal lens.
    Last Post: 11-04-2011, 09:30 AM
  5. Front Signal Light Problem 09TW
    By cacosta in forum Technical Help
    Last Post: 05-13-2011, 06:17 PM
