Front Brake Adjustment
Results 1 to 3 of 3
    Junior Member doormatt8@msn.com's Avatar
    Aug 2010
    4
    front break is screwy. cant get it to adjust. got new brakes but my old ones were identical. not that old completely within spec so I left the old ones ones on. you have to pull all the way to the grip unless it's at the tightest adjustment on both the lever and the brake. way too much free play.
    If I change the angle of lever on the drum that the cable attaches too is either way too tight and can't get the cable on, or way to loose and doesn't even work. it seems it will only fit in two positions even though there are lots of teeth. The brake works good it's just acts like it's at the end of the adjustment. rotor is in spec too.
    Stretched cable?
    Should that lever on the drum be adjustable to multiple positions?
    Bent break lever?
    1996 TW200 Edmonton, AB
    590
    I changed my cable the other day because of that, seems to have fixed it.
    Ephrata, WA
    1,125
    I agree, the front brake is tough to adjust. I've learned to take off the cable at the hand lever to give you some slack. Attach the cable to the drum and then to the hand lever. Adjust the freeplay screw at the hand lever to tighten it up. I've also removed the screw that holds on the hand lever, attached the cable end to it and used it as a fulcrum to pull the cable tight. Then I would insert the screw. I've fiddled with the position of the lever at the drum (on the splines) and it seems to only work in a few spots. Your cable may be stretched also. Mine was and could never get the brake correct. A new cable solved my problem.
    1990 TW200
  1. Front brake '99 - '01
    By dutchbat in forum Technical Help
    Last Post: 05-25-2013, 05:46 AM
  2. WTB Front brake line
    By xdac in forum TW200 Classifieds
    Last Post: 06-14-2012, 09:34 PM
  3. Front Brake For a Dummy
    By sorethumb in forum Technical Help
    Last Post: 10-02-2011, 06:33 PM
  4. Front Brake Pads
    By Hendragster in forum Technical Help
    Last Post: 10-08-2010, 04:01 PM
  5. WTB - Front (brake) hub.
    Last Post: 09-24-2010, 01:14 AM
adjust front drum brake tw200
front brake adjust tw200
how to adjust 1986 yamaha tw200 front brakes
tw200 brake pad replacement
tw200 break pad
tw200 drum brake adjuster
tw200 drum brakes
tw200 front brake
tw200 front brake adjusrment
tw200 front brake adjustment
tw200 front drum brake
tw200 rotor width
