ATV seat pad
Results 1 to 9 of 9
Thread: ATV seat pad
    Senior Member lakesideboo's Avatar
    Lakeside, CA
    110
    I just bought a Wal-Mart ATV seat pad and when I put it on the seat the buckles were in the way and couldn’t get the seat back on does anyone have any suggestions how they put theres on?
    Senior Member Purple People Eater's Avatar
    Oct 2010
    Everywhere! Living Life on the Road.
    445
    We cut the buckle off and use shoe string to loop it onto the seat.
    "One's destination is never a place but rather a new way of looking at things" - Henry Miller
    Senior Member BillMichaels's Avatar
    SF Bay Area
    278
    Quote Originally Posted by lakesideboo View Post
    Some people loosen up the slack. Some cut off the buckles and connect with thin bungie material. You'll appreciate the new seat cover.
    1998 HD FLHTC
    2004 TW200
    2004 TW200
    Ephrata, WA
    1,125
    I cut off the buckles and loosely tied the straps on one side to the strap on the other side. When you put your seat back on, most of the slack will be taken out and it will fit snug. For the rear strap, I cut off the buckles and straps and used a piece of rope.
    1990 TW200
    Senior Member mrlmd's Avatar
    1,157
    I initially had that problem but if you slide the pad a little forward, it all fits fine. See my avatar, the buckles in that position are underneath the seat and out of site.
    Member StevieP's Avatar
    Irwin, PA
    86
    It took me awhile to find the "sweet spot" for the cover to fit also but after a little bit of messing around with it, I got it. It's not gonna fit like a glove, it'll wiggle a little but it's a whole heck of a lot cheaper than buying a custom seat....
    Lakeside, CA
    110
    Thanks for all your help I will try it this weekend.
    Senior Member gskeem's Avatar
    Black Diamond, WA
    162
    Just put mine on yesterday when I replaced the battery. I got rid of the snap ties and used the Dremel on the female end grinding down so just the plastic rectangle part was left. Then I threaded in a 24 inch Hook and Loop cinch strap through that. I had to remove the entire rear buckle system and go through the loop. Looks clean and fits like a glove very snug.
    1996 TW200 Edmonton, AB
    590
    Left my buckles on, they fit fine in this position:
  1. Seat/seat cover
    By Abonnette86 in forum TW200 Classifieds
    Last Post: 03-14-2013, 07:46 PM
  2. Seat Pan
    By lyfestyl in forum General Discussion
    Last Post: 08-07-2012, 02:52 PM
  3. WTB - Seat or Seat frame
    By praeses in forum TW200 Classifieds
    Last Post: 08-15-2011, 10:14 PM
  4. Best way to Recover a seat? My seat is Teal :(
    By panamacolin in forum Technical Help
    Last Post: 07-17-2011, 06:51 PM
  5. FS--TW seat
    By cyclecat in forum TW200 Classifieds
    Last Post: 04-26-2011, 09:31 AM
