chain tension
Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: chain tension
    Junior Member hoofhearted529's Avatar
    Jan 2011
    24
    how much play should you allow in the chain. mine seem to shift a lot nicer with the chain relatively tight. i bought an o-ring chain because the stock one kept stretching. spent 50 bucks, and the new one really isn't much better. am i running my chain to tight?
    866
    Maybe. Look in the manual and make sure you are adjusting it to spec.
    It's normal to adjust the o-ring chain once or twice as it breaks in. If you keep having to adjust it often after that, you've got problems.
    Quote Originally Posted by Rodney View Post
    It's normal to adjust the o-ring chain once or twice as it breaks in. If you keep having to adjust it often after that, you've got [s]problems[/s] worn out sprockets and have already ruined your new chain.
    Senior Member Turtle Chaser's Avatar
    Aug 2010
    Fieldbrook Valley CA northcoast
    254
    Hello hoofhearted529, so did you install new sprockets with the new chain? This is a necessity unless they are virtually / really really close to new. Like maybe less than 100 miles. Even that could be too much. The factory chain starts stretching / wearing immediately and wears the sprockets to match. Not good for a new o-ring chain .
    GOD BLESS & RIDE SAFE, TC____________ BC rides: Honda SL100, Honda TL125, Penton125 ISDT, KTM400 ISDT
    now riding '06 TW w/ Jimbo Window, Acerbis bushbusters, ProTaper bars w/risers, Pro Grip 737's, Osram Rally headlamp w/modulator, turn signal beeper, Kenda k270 4.00 x 18,
    triple horns w/relay, big pegs, folding shifter, tuned carb w/drilled slide, 15/50 w/D.I.D. O-ring, RedLine 20w/50, Sterns w/extra padding, extra LED brake light, xt225 brake arm, rear Cycle Racks w/hacked milk crate. Hidden Content
    Jan 2011
    24
    yeah i dropped down to a 47 tooth.
    Jan 2011
    24
    i bought the bike used with no manual. i was just looking for a roundabout answer as far as how much slack most people allow. (1/2 inch, 1 inch ect.)
    Jan 2011
    24
    (side question) i said b4 that my bike seems to shift smother with the chain pretty tight. am i running a risk of damaging the bike by running the chain to tight? thanks for the help i appreciate it.
    866
    Don't run it too tight. You will risk damage to the countershaft bearing and other parts.
    Slack should be 30-40 mm (1.2 - 1.6 inches).
    6,998
    Owner's manual : 1.4" to 2.4" (35mm to 60mm)
    Shop manual : 1.2" to 1.6" (30mm to 40mm)
    Figure that one out!
    With the top part of the chain taught, using the trailing edge of the piece of plastic from the chain guard that hangs below the swing arm, I have mine set at about 2.25" vertical slop.
    People tell me it is to loose but if I go one notch tighter on the snail it is only about 1.2" and the rule is "a little loose is better than a little tight".
    The tightest the chain gets is when the primary sprocket shaft, the swing arm shaft and the rear axle make a straight line. If there is a little slop when these three points align then I think you should be OK.
    Fifty bucks for an o-ring chain sounds like a bargain. I paid $35 for a regular chain and have maintained it religiously. It has over 11K miles on it and looks in great shape. I did replace the sprockets with the chain so it was an entirely new package.
    Good luck!
    Jan 2011
    24
    hey thanks allot. i defiantly have mine too tight. ill make the adjustments. thanks again.
  1. The $5 chain
    By disenfranchised in forum General Discussion
    Last Post: 08-02-2012, 10:22 AM
  2. better chain
    By brent morley in forum General Discussion
    Last Post: 03-12-2012, 10:16 AM
  3. WTB 428 chain
    By Roninboise in forum Technical Help
    Last Post: 02-15-2012, 06:46 AM
  4. 520 chain
    By TeeWee in forum Performance and Customization
    Last Post: 02-19-2011, 01:48 PM
  5. help chain
    By Logan in forum General Discussion
    Last Post: 01-25-2011, 10:18 AM
chain slack
how much chain slack
tw 200 chain tension
tw200 chain tension
tw200 chain to tight or to loose
which brand 55 tooth rear sprocket
