stripped out bowl drain screw
Results 1 to 8 of 8
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    i was just wondering if the drain screw for the carb bowl is a special type of screw? can i just put in a set screw with matching threads? i have not gotten the screw out yet so im not really sure what it looks. all the diagrams i see are not good for viewing finer details. i cant imagine why it was put in that tight in the first place, its almost like the screw has thread locker on it. the material the screw is made out of seems to be very soft and stripped with the first turn, are they aluminum?
    Tennessee
    1,301
    It's a JIS screw. You can read about it here. A normal phillips head will strip it because it's not deep at the center. The best way to get those if you don't have a set of JIS drivers is to just use a flathead with care (EDIT: or grind down a phillips head driver a bit flatter.)
    A normal screw might work, but I think the issue is that they won't seal well enough to keep from draining.
    Jun 2011
    Dothan, AL
    1,715
    2005 TW200 (SOLD)
    2013 DR650
    Senior Member wayne's Avatar
    Rathdrum Idaho
    108
    mr zannini, the bowl drain screw is not just a regular screw it's more like a needle valve, but they are cheap from the dealer. The number is 4JP-14104-00.
    Wayne.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,403
    Quote Originally Posted by mr zannini View Post
    Yes.
    It has a rounded end to close off the passageway that drains the bowl.
    Just before the rounded end, the screw is tapered so that when the the screw is fully closed, fuel from the overflow tube can still flow around the screw and out the drain.
    See screw at lower left of photo.
    jb
    Jul 2011
    putnam,ct
    428
    thanks for the replies everyone. very helpfull. hopefully ill be able to get it out. it dont seem like its something id wanna have to drill out.
    FL. GA, NC
    2,403
    It's not absolutely necessary that you remove the drain screw. As long as you can remove the bowl (replace the bowl screws), you can accomplish the same draining of the bowl, and make sure the overflow tube is not clogged. It will just take a bit longer.
    jb
    Senior Member gfletcb's Avatar
    Jun 2011
    181
    I ended up replacing mine as I stripped it a bit trying to drain the bowl before my jet change experiment. Much easier with the bowl off the carb and on a bench so you can get some leverage on it.
    5 or 6 bucks for the kit that will come with a couple extra washers you wont need.
  1. Carburator drain screw stripped
    By Matojo in forum Technical Help
    Last Post: 10-20-2015, 03:51 PM
  2. float bowl drain screw
    By boylstonrider in forum Technical Help
    Last Post: 12-20-2013, 03:46 PM
  3. stripped the drain screw on my TK carb!
    Last Post: 01-03-2013, 11:59 AM
  4. Float Bowl Screw
    By mike m in forum Technical Help
    Last Post: 09-04-2011, 08:03 AM
  5. Part number for Carb float bowl drain screw?
    By RadV in forum Technical Help
    Last Post: 09-16-2010, 07:16 PM
