I knew I needed a Kickstarter
Results 1 to 10 of 14
    Moderator vuldub's Avatar
    Aug 2010
    Calgary, AB Canada
    652
    Well I finally had that moment when I'm glad I did the kickstarter add on to my 2004. We started out down a steep hill and were about 2 miles in when I started thru a very innocent looking muddy water wet spot in the road - you know the kind that fills a small rut about 8 feet long and 3 feet wide. No need to go around, how deep can it be - the road was fairly rocky, should only be 6 inches. Obviously some two wheeled drive truck got stuck previously and spun all the rocks out of the rut, because I dropped in to the top of foot peg and the engine died. Lizrdbrth, if you're reading this, I know, I didn't vent the carb breather tube up yet.... the stuff is on my bench and we were in a hurry to get riding.....
    We pulled the bike out and I pushed the electric start. After about 8 cranks, nothing, wouldn't crank anymore. Battery was too low to turn the engine over! The battery must have been low when I started and in the short drive, it hadn't charged enough yet. Thanks goodness for my new kicker! It was about 10 minutes before it would fire again (not sure what goes with that....). Pulled the plug and it was good, not wet. Smelled a bit flooded, perhaps. Anyhow, we were off and running.
    I had made some jumper cables after my last stall and could have used them, but I am really glad I had a kicker.
    I pulled the vent tube up out of the ring behind the engine and crossed several streams with no difficulties. The water in the stream was about 16in deep in places and the bike never stalled. I'm wondering if forward momentum creates an air pocket behind the engine that stays free of water. Or perhap my big ATV tire washes lots of water down on the tube and sometimes it sucks and sometimes it doesn't. Maybe pulling the vent tube up solved most of the problems? Kinda weird it worked fine in the creek crossing (8 in total - no problems). It's definitely not electrical, otherwise it would happen in the creeks too.
    Regards...Wes
    Senior Member BillMichaels's Avatar
    SF Bay Area
    278
    I like the idea of mini jumper cables. It's great when you're riding with a buddy.
    JimboC- - Are your reading this???? This is a perfect example of why you should design a kevlar rear wheel housing shield.
    1998 HD FLHTC
    2004 TW200
    2004 TW200
    Aug 2010
    Calgary, AB Canada
    652
    Quote Originally Posted by BillMichaels View Post
    They are easy to make, just some good gauge wire and alligator clips soldered on the ends. I wired a 2-wire plug for heated gear, so one end of my jumper cables is the 2-wire plug and the other is alligator clips. Just make sure the wire gauge can handle the load. I think I used 12 gauge wire.
    Regards...Wes
    Senior Member chipyting's Avatar
    Eugene, Oregon
    264
    Can you push start or roll down a hill and start the tdub?
    Jul 2011
    1,123
    Didn't want to hijack your post so started a new one here https://tw200forum.com/index.php?/top...asis-on-cheap/ <--- This is good enough reason to have a properly working e-start AND a kick start
    ITCB
    Aug 2010
    Calgary, AB Canada
    652
    Quote Originally Posted by Chip Whiting View Post
    I suppose, with some effort, but not when you are stuck in the mud!
    Regards...Wes
    Eugene, Oregon
    264
    Quote Originally Posted by vuldub View Post
    OK, good to know. Thanks.
    TWs are easy to push start--fast walking speed, 3rd gear, and traction. Like the 3 things necessary to have fire, one always seems to be difficult to come by. Like making fire, the worse the weather the greater the difficulty.
    Aug 2010
    Calgary, AB Canada
    652
    One issue with push starting the bike after it stalled in water. This has happened twice to me now, and each time it needs about 10minutes of waiting before it will start. If I spent that first 10minutes trying to push start it, I would be exhausted. I would hate to run it down a nice long hill and not have it start by the bottom.....Having the kicker was really nice. I tried it a few times, waiting, tried, waited and it finally started.
    Regards...Wes
    Frosty Hollow
    13,172
    Last year I went on a camp trip with a known bad battery. Push starting, downhill or not, still sucked everytime I shut the TW off (which I do alot). We also took a portable jump starter and I would use that in the morning to minimize my huffing and puffing. Carried the jumpstarter on the ATV just in case too.
    I've wanted to add the kick start, and will sometime, though in my case keeping the battery in good condition is a must. However, going through water was never a concern until now. Nice to know, as is the reminder of the vent tubes.
  1. Adding a Kickstarter
    By Idaho04 in forum Sticky threads
    Last Post: 05-14-2015, 06:45 AM
  2. Could have used a kickstarter today
    By howardgene63 in forum General Discussion
    Last Post: 08-03-2013, 02:51 PM
  3. kickstarter question
    By dutchbat in forum Technical Help
    Last Post: 05-23-2013, 07:45 PM
  4. Kickstarter questions
    By Larry in forum Technical Help
    Last Post: 06-15-2011, 10:15 PM
  5. Trade my engine for your kickstarter?
    By TW-Brian in forum TW200 Classifieds
    Last Post: 02-06-2011, 08:31 PM
grand vitara suzuki 2002 kickstarters
