How complicated is it to mount a bigger front disk?
Results 1 to 10 of 10
    Senior Member Dark Sol's Avatar
    424
    I have a ninja 500 that is only good for parts and it has a really big front disk - not sure the exact size but probably 300-350mm and my 2001 TW probably has what a 220mm disk I think the specs say? It would make a big difference in stopping power which would be nice in the mean time while I'm riding it until it finally sells, which would help sell it too cause the TW disk is definitely not the biggest bite in the world.
    So, would it just be a matter of swapping out the disk and the caliper or do I have do swap out all the lines and brake fluid reservoir too? How complicated can it get? Seems simple but I thought I would ask before I take the TW's brake apart.
    Thanks
    2008 CRF230L
    2006 CBR1000RR
    2007 CB919 - 70k Miles and still runs like new!
    * 2001 TW200 (Sold after 15k miles of fun)
    Desert, SoCal
    7,369
    Don't go taking it apart so quick.
    Your Ninja disc won't fit the "3 groups of 2" bolt pattern on your TW wheel. No how, no way, short of having an adapter plate machined. Then you'd need to have a plate machined to move your existing caliper to the rear so it will clear the new disc, and have it returned to the correct offset.
    Lotsa work and cubic dollars.
    There may be an existing kit for one of the few other bikes which share our bolt psattern. Early YZ80's Xt's and TTR's are among the few but there probably isn't much demand.
    Cubic dollars again, but complete kits with less chance of you ending up room temperature.
    Senior Member evan's Avatar
    Aug 2011
    Woodland, California
    2,126
    Quote Originally Posted by Dark Sol View Post
    Thanks
    Don't even think about it, no way. The Tw is a pretty light bike so ur disc should work fine. I have a 89 with the drum and it stops me just fine.
    Devon, England.
    614
    Have a read here, all credit to Sinophilia > https://tw200forum.com/index.php?/top...mm-brake-disc/
    Jun 2011
    AZ
    793
    Don't even bother cause the bike doesn't even go that fast to need bigger brakes. Plus its a big negative if you go off roading. Your bound to bang it up and bend it being that big.
    Desert, SoCal
    7,369
    Quote Originally Posted by uktw125 View Post
    Not sure what that little booger costs, but that's the way to go.
    As others have pointed out, it's not a real wise choice for an offroad TW. A disc that large tends to be pretty hard to control in soft stuff and is vulnerable to damage.
    On a street ridden bike that would be the ticket.
    tw_parts.com Sebastian has a kit.
    Desert, SoCal
    7,369
    Assuming I did the conversion correctly, the price isn't all that bad. I doubt you could get a Galfer or similar kit for any less domestically, even if they offered one.
    Desert, SoCal
    7,369
    FWIW, the biggest STANDARD rotor I've found for our bolt pattern is a 245mm, used on some old YZ's and 2-stroke WR's.
    Just thought I'd save some of you from reinventing the wheel, so ta speak.
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    Add a supercharger then bigger brakes.
  1. Front Brake Issues -disk
    By bikerjosh in forum Technical Help
    Last Post: 08-31-2015, 09:02 PM
  2. Front disk brake possibility
    By flyhunter3825 in forum Performance and Customization
    Last Post: 06-19-2013, 03:23 PM
  3. Front disk brake cover
    By abuck40 in forum Performance and Customization
    Last Post: 03-18-2013, 09:52 PM
  4. front disk brake cover
    By mdesheles in forum Performance and Customization
    Last Post: 03-18-2013, 06:58 PM
  5. Bigger front tire?
    By movingtarget in forum Performance and Customization
    Last Post: 10-09-2010, 02:33 PM
