TW good and bad terrain
Results 1 to 10 of 11
    Junior Member wilderness's Avatar
    Aug 2011
    22
    I mostly ride in the desert, so I'm accustomed to rock gardens and loose sand. On that type of terrain, especially the rocks, I love the big fat tires on the TW. I pretty much just point the bike were I want to go and twist the throttle. I'll steer around big loose rocks but anything else in my way just just gets run over. I've ridden more conventional dirt bikes a few times but to me they didn't feel as secure as the Tdub. However, last weekend I got into some mud puddles left over from last week's rain and I was having a really hard time. The back end kept getting away from me. The back tire was skidding over the top of the mud rather than digging in. I have little experience in mud so I'm sure most of the problems were my fault.
    Still, it aroused my curiosity. Are the narrower tires on a conventional dirt bike better in mud than the TW? That begs the more general question: On what types of terrain are the extra-wide TW tires a liability as compared to a more conventional tire?
    Jul 2011
    1,123
    If it is a thin layer of mud, thinner tires would create more ground pressure (smaller contact patch, same weight) which would allow the tire to "dig down" to a firmer base, whereas the wider tire might be likely to "float" on top.
    You guys have mud in the desert?
    ITCB
    Desert, SoCal
    7,369
    Are you airing down?
    Airing down helps not only with traction via a larger contact patch but in helping the tire shed mud buildup.
    When you're aired down enough the tire is somewhat flat on the bottom. as it rolls it then "pops" back into its original curvature, helping to sling the mud from between the treads.
    Aug 2011
    22
    Yes, I forgot to mention that. I generally run the tires about 13 lbs off-road.
    The mud was an annoyance but nothing more. It created more questions than problems.
    BTW, there are wild horses in the area and they like to congregate at the mud holes. So this wasn't just any old mud. It was mud full of horse manure. The idea of falling is always unappealing, but in this case it was extra-unappealing.
    Desert, SoCal
    7,369
    Snot is snot. lol. You get a pass on this one. There are some types of mud that no tire can shed.
    It's been a long time since I've run the stock tires. I'm guessing that you could go a bit lower if need be.
    Low pressures will result in pinch flats in desert rocks. I run 12-13psi in the desert for that reason. Also, desert tends to have long stretches at 35-40mph on packed dirt and rock, which can build up heat and damage a tire that is flexing a lot from too low pressure, especially since deserts are subject to high temperature.
    Desert mudholes usually have a dry clay or silt bottom that is wet and slimy on top, hard and slick underneath, and slicker than ice where they meet. Add in deposits from these guys and it's slip, slide, and kersplat. It can take days for water to soak more than ankle deep, but it only takes a sprinle of dampness to turn the horizon between the layers into untractionium. Worse, there can be dry, hard clay under a thing wet layer under a dry layer covered with dust from the last sand storm--looks dry, slick as black ice. SURPRISE!!!!!
    Wet red clay of Georgia and Alabama is almost as slippery.
    Nothing gets traction in owl snot. A front tire with a very aggressive tread sheds mud well. Shift up a gear and keep the rear tire spinning to sling out the mud. Hope for the best.
    Aug 2011
    22
    "Desert mudholes usually have a dry clay or silt bottom that is wet and slimy on top, hard and slick underneath, and slicker than ice where they meet. Add in deposits from these guys..."
    You nailed it Qwerty! That's exactly what it was. Actually, the mud layer was so thin that buildup on the tires was not an issue. But it was slick as ice.
    You mentioned Georgia clay. I've seen the same thing in southern Utah. There have been times in my 4x4 when forward motion seemed due primarily to the jet thrust created by trowing mud from all 4 tires. Is there any significant difference between TW tires and skinny tires in that sort of stuff.
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    I run 10 psi in both front and rear and usually go around the mud puddles
    Senior Member Bagger's Avatar
    Jan 2011
    Central WA
    1,050
    Wild, I don't have close to the miles that some of these guys that have already answered you have (not that they are old ) just "sperianced".
    But to directly address your question about skinny and fat tires. . . skinny tires will tend to cut deeper and through that untractionium (I'm diggin' that Q!) layer. I love the big tire on the rocks, the rock gardens and in sand, but in really slick, sticky mud I feel it's a liability. To me and I'm sure not an engineer, the tire is too rounded at the corners, and the traction blocks are too close together to allow the tire to grip in the goo well. Or on slick rock for that matter.
    Back when I lived in Virginia, I always ran the biggest, fattest tires I could manage on my 4X4s to help the truck not sink in the slop, because once you started down, you ceased to move forward. You wanted that huge footprint to handle that type of mud. Once I moved out here, I quickly learned that a tall, narrower tire was the ticket to getting through the mud and down to the rock layer that we have most everywhere here, and to get down through the snow layer to ground.
    Simply put, where there is a solid bottom at a reasonable depth to bite into tall and skinny rules. Where it doesn't matter, or there isn't a practical bottom, fat wins the day.
    I am struggling right now between accepting the TW for what it is, and making some mods to it (that many remarkable members on here have already pioneered ) that would allow it to traverse the areas that I want to explore easier.
    It is a trail bike, not a dirt bike. HOWEVER, I feel it covers dirtbike duties much better than a dirtbike covers trail duties. . . .
    Hopefully there is something helpful in this mush.
    Bag
    "The TW may be slow, but the Earth is patient" - MK
    "If I'm wrong, and it turns out that you hate it, I'll send you all my Barry Manilow albums." LB
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    Just carry an air compressor, adjust as needed. I've got a nice Cyclepump, nice expensive and heavy, I prefer the cheapo slime pump.
  1. GOOD OR NOT?
    By SMALLBLOCK116 in forum General Discussion
    Last Post: 03-09-2013, 08:19 PM
  2. Good MPG
    By stephenmarklay in forum General Discussion
    Last Post: 03-02-2013, 01:26 AM
  3. Any good KLR forums?
    By DonBenito in forum Off-Topic
    Last Post: 11-23-2012, 10:12 AM
  4. Good Deals on TW's?...
    By canadainshiver in forum TW200 Classifieds
    Last Post: 09-06-2012, 06:21 PM
  5. Hello...and good day!
    By ZXtasy in forum General Discussion
    Last Post: 12-18-2010, 11:51 AM
