float bowl chamber
Results 1 to 2 of 2
    Senior Member phazer's Avatar
    Jul 2011
    putnam,ct
    428
    does anyone know where i could buy a float bowl chamber? everywhere i looked you have to buy the whole darn carb.any help would be greatly appreciated!
    Senior Member TW2007's Avatar
    Central Washington
    464
    It appears you can buy every part of the carb individually, except for the bowl and body.
    You might want to try a motorcycle salvage yard. Here's one in your neck of the woods.
    Cycle Salvage; West Haven, CT; 203-933-1600
    Good Luck
  1. float bowl drain screw
    By boylstonrider in forum Technical Help
    Last Post: 12-20-2013, 03:46 PM
  2. Float Bowl Gasket Sealer?
    By rmoore2112 in forum Technical Help
    Last Post: 12-04-2011, 09:35 PM
  3. Float Bowl Screw
    By mike m in forum Technical Help
    Last Post: 09-04-2011, 08:03 AM
  4. Carb float bowl screws
    By jbfla in forum Technical Help
    Last Post: 10-05-2010, 03:57 PM
  5. Part number for Carb float bowl drain screw?
    By RadV in forum Technical Help
    Last Post: 09-16-2010, 07:16 PM
