Rear shock spring removal tool
Results 1 to 6 of 6
    Member bruisr's Avatar
    69
    Does anyone know what size the spanner wrench is for replacement of the rear shock spring (want to replace it with a Hyper Pro). Also where i can purchase one?
    1993 TW/1200 origional miles/FMF/Clarke Tank/Pro Bend Hand Guards/Pro Taper chain/Larger Foot Pegs/Pro Taper grips/PIAA 35w/Cyclorack/LED stock turn signal conversion/Storage tubes/Kenda 270 5.10 front tire/Glock 45 Handle Bar mount(for the desert runs)!
    Quote Originally Posted by bruisr View Post
    Hyper Pro might sell them.
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,515
    Not clear on your question. You do not need a "spanner" when replacing the spring. YOu certainly will need a spanner to remove the shock from the bike. Any metric wrench set will have the appropriate wrench. I am sure you could make progress with an adjustable wrench. I now have a HyperPro spring on my Banshee body. You need to restate your question in order for us to help (more). Gerry
    Take care my Friend.........
    69
    Once the shock is removed-is a coil spring compressor (or similar) required to take the pre-load off the shock so the spanner wrench (or punch) can remove the top nut of the assembly so then the spring can be removed and replaced. Sorry I haven't done this before..just viewing on the bike what it will require for removal once the shock is off the bike.
    Devon, England.
    614
    The spring is held on by a big C-clip, not a nut.
    Paradise, Calif.
    3,515
    My HyperPro.......
  1. Removing the spring from the shock
    By nfpgasmask in forum General Discussion
    Last Post: 07-23-2013, 03:00 AM
  2. Rear fender and mirror removal
    By esw28 in forum Performance and Customization
    Last Post: 04-04-2013, 08:11 AM
  3. Tool Less Seat Removal
    By n2o2diver in forum Performance and Customization
    Last Post: 01-16-2012, 06:06 PM
  4. REAR SHOCK
    By Gerry in forum Sticky threads
    Last Post: 06-05-2011, 08:38 AM
  5. Rear Shock Mod
    By wiigstyle in forum Performance and Customization
    Last Post: 10-27-2010, 12:58 PM
