So I bought a bike............
Results 1 to 10 of 11
    Senior Member TuggerHiller's Avatar
    May 2011
    Long Island, NY
    362
    found a '07 with a cyclerack attached..........so I'm thinking what next.
    on a rainy saturday I started with the positive terminal that bugged me
    put a wire loom over the frame
    then saw a bolt missing from the rack....was actually broken off
    lucky it wasn't a blind hole
    then installed a fused power outlet direct to battery
    positioned it behind windscreen
    and grounded to frame, but I dont believe in drilling blindly into frame so I used an exhisting hole and bolted through...
    all in all a productive couple o'hours
    2007 T'dub
    Cyclerack/Dual Northern Tool Boxes/AVG Miglia Helmet/Infamous Tubes/Fanny Pack/ATV Tank bag
    Senior Member bcscammell's Avatar
    Oct 2011
    264
    Quote Originally Posted by Wannabee onTug Hill View Post
    on a rainy sunday I started with the positive terminal that bugged me
    The first time I had the seat off I was suprised to see how close the positive battery clamp was to the frame. It bugs me everytime I look at it. I have dropped the bike a few times and have always felt a need to check the battery afterwards. While it has never caused a problem I think I'll do the same thing you've done. Thanks for the idea.
    May 2011
    Long Island, NY
    362
    Thank MrDNA its an Idea inspired by him ..........I just used scraps I had laying around
    2007 T'dub
    May 2011
    Long Island, NY
    362
    I bought a bolt to tighten the rack down.............put the seat back on and snapped one of the seat bolts...........Luck o' the Irish .........
    Guess I better buy a handful
    2007 T'dub
    Maybe invest in a torque wrench and learn how to use it.
    Devon, England.
    614
    It looks like your rack is bent or not lined up properly. Might be an idea to see if you can straighten it or your new bolt will break again.
    I only use a 1/4" drive socket set on any bolts with a 10mm head or smaller and still go steady.
    Any thing bigger gets torqued to spec.
    No stripped threads, no broken broken bolts.
    Aug 2011
    Cayce, SC
    3,109
    It may be different strokes for different folks but I had to put in the center two bolts about 3 threads in and then put on the side bolts and slightly tighten each of them kinda like a car tire going in an "x" pattern. It should distribute the force on the bolts evenly if you do it like that. Kind of a pita but it will be extra rigid and durable if you do it thatway. It's gonna be really hard to just thread a single bolt on a cyclerack
    Also, i've been trying to figure out a quick release seat system but I cant find the right hardware. I'd like to do one of the screws with the hole in it you push a pin through...
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Make the hardware. Cut the head off a bolt. Drill the shank of the bolt. Drip a little permanent Loctite on the threads. Install the bolt in the seat nuts. Wait for the Loctite to set. Install the seat. Install cotter pins. Done.
    Desert, SoCal
    7,369
    Aug 2011
    Cayce, SC
    3,109
    Thanks LB! Love the picture wire and terminal rings idea. Will be copying that one for sure. Headed to ace tomorrow for parts.
  1. just bought
    By joeband in forum General Discussion
    Last Post: 09-30-2015, 11:39 PM
  2. I bought a KLR650!
    By DonBenito in forum Off-Topic
    Last Post: 06-08-2013, 04:30 PM
  3. Why I bought the TW200
    By scotti158 in forum General Discussion
    Last Post: 05-27-2013, 08:58 PM
  4. bought a 1987 Yamaha tw 200 bought need helppp!!
    By Guelox in forum Technical Help
    Last Post: 12-21-2012, 03:47 AM
  5. Bought a 92
    By Puritan21 in forum General Discussion
    Last Post: 09-17-2012, 02:32 AM
