I Hate Weight Plates
Results 1 to 10 of 11
    Senior Member TuggerHiller's Avatar
    May 2011
    Long Island, NY
    362
    I cant trip traffic signals to let them know I'm there............anyone else know a secret to doing this?
    2007 T'dub
    Cyclerack/Dual Northern Tool Boxes/AVG Miglia Helmet/Infamous Tubes/Fanny Pack/ATV Tank bag
    Senior Member GapRunr's Avatar
    Jun 2011
    Friendsville, TN
    457
    Check the laws for your state. In most states you can treat it as a malfunctioning signal, which it is. Look both ways and proceed when its safe to do so. I've done that many times here in Tennessee.
    GapRunr
    Current bikes TW200 * R1200GS ADV * R80g/s * KLR250 Miami Vice Edition * Hawk GT - For sale!
    jim
    jim is offline
    Senior Member jim's Avatar
    Indio, CA
    100
    Put some magnuts on the bottom of your bike
    Join Oathkeepes.org
    Because Home Land Security Begins @ Home: BPAUX.org
    Guns only have two enemies: Rust and liberals
    Aug 2011
    Cayce, SC
    3,109
    I need to talk to someone here about that as well. I have sat at a light for 4 minutes before, waiting for a car to pull up behind me to trigger the switch. Now I just make right turns and u-turns
    '86 BW80 farkled to size
    '10 TW200 you will be missed
    Junior Member 6011's Avatar
    Mar 2011
    Coombs, BC
    4
    Not sure if it the same everywhere, around here they use a coil of wire under the pavement. It works like a metal detector. I think it is most sensitive right in the centre of the coil, but I might have the wrong, it might be as the metal passes over the coil. Either way, it has nothing to do with weight.
    Correct, it's metal interfering with a stable electromagnetic field, most sensitive the closer to the actual wires. It's a metal detector, not a magnet or scale. A couple inches sometimes makes a big difference. Big trucks with tall tires fail to set the darn things off. If you can see the grooves for the wires, ride directly over them. Sometimes putting the kickstand's foot directly down atop the wire will do the trick. Steel-toed boots on the groove sometimes work. Bicyclists lay their bikes down with a frame tube along the groove with results.
    Federal law requires traffic control devices to function properly, so find out which road/street/highway department is responsible for the light and politely contact the department. Volunteer to invest a litttle time riding across the device so it can be set properly. the problem is, cranking the sensitivity up high enough to detect a motorcycle often allows false triggering by vehicles passing in adjacent lanes. This has been a recognized problem with a solution involving installation techniques well known for 30 years, but dumbassed government engineers don't care. This dumps the problem on the department maintenance folks, and they are frustrated, so try to be positive with them.
    Senior Member Dave Nafziger's Avatar
    Aug 2010
    264
    I've had more trouble with Mo-peds than the TW, but sometimes getting cross-wise in the street trips it. -GB
    Senior Member cptrout's Avatar
    S. Torrance (So. Cal.)
    353
    I have the same problem, I think we all do that ride the street. I've called the city to no avail. I talked to the local PD and they tell me they have the same problem. They also told me if I wait two cycles of the light without getting a green to proceed with caution thru the red and that 95% of cops would not cite me. I usually just go the opposite direction and flip a U.
    This link might help.
    http://www.wikihow.com/Trigger-Green-Traffic-Lights
    May 2011
    Long Island, NY
    362
    thx all
    2007 T'dub
    Senior Member Xracer's Avatar
    Lake Placid,Florida
    3,815
    Think it's bad on a motorcycle? Try getting it to trip with a carbon fiber bicycle!
  1. I hate you all
    By maddawgj in forum General Discussion
    Last Post: 06-15-2013, 11:33 AM
  2. don't hate me
    By operose in forum Off-Topic
    Last Post: 09-30-2012, 08:21 PM
  3. The 1 thing I hate about the TW200
    By ceramite in forum General Discussion
    Last Post: 12-18-2011, 02:50 AM
  4. I Hate It When She's Right...
    By Kev250R in forum General Discussion
    Last Post: 07-18-2011, 11:34 PM
  5. im starting to hate my tw
    By dizzle2 in forum Technical Help
    Last Post: 07-17-2011, 10:02 AM
