Trailer recommendations
Results 1 to 10 of 16
    Member mtngirl's Avatar
    Hailey, Idaho
    44
    Hi guys, looking for some advice. I have decided that it is a trailer I need. I would love the Kendon foldable 3 dirt bike trailer, but not in the budget so does anyone recommend a good second choice. I definitely need it to carry two bikes. Also, what are the most important things I need to look for when shopping for a trailer. I have zero experience towing. I appreciate any thoughts. I figured this is a good time of year to get my research done and find a good used one over winter. Thanks!
    Great, another freakin' oil thread.
    I've given up on rail trailers for bikes. Too many slips and falls. I'll take a solid bed every time. Virtually every problem I've ever seen anyone have with trailering motorcycles stems from cutting corners on equipment and/or neglect. You don't have to pay extra for Harley or Beemer branded gear, but it is not wise to cut corners too sharply.
    Anywho, I've been quite satisfied with my Harbor Freight cheapo 4x8 kit. Best bang for the buck. Be sure to spring for the 5.30-12 LRC 6-ply rated wheels and tires. The bigger, heavier-duty wheels and tires provide a smoother ride and last longer than smaller tires, and the difference in cost is minimal. Be aware that trailer tires have relatively thin sidewalls and will normally lose pressure over time. Be sure to max out the tire pressure EVERY time you hook up the trailer or the tires will fail from under-inflation or overloading that cause heat to build up.
    Clean and repack the wheel bearings and hubs with a real quality wheel bearing grease. The provided grease is no better than slime scraped off dead fish. It actually smells like fish slime. Repack wheelbearings every 2 years or 10,000 miles and you'll never have a problem.
    Take the quadralateral piece that goes on top of the junction of the tongue and the two angle brackets and duplicate it in 1/4-inch steel. Bolt the extra reinforcement on the bottom of the tongue and brackets directly below the original.
    Bolt a 6-foot long piece of 1 1/2-inch angle iron between the front cross member of the bed and the tongue assembly, with 1 foot sticking out each side. I just drilled the angle where the stock assembly bolts go. No problems. Give the angle a coat or two of Rust-O-Leum and it's good for years.
    With these few mods, you should now have a rolling trailer frame. Next thing you'll need is a deck for the frame. When you assemble the trailer kit, do not try to make it fold. The trailer is much more solid if you forego the folding option and do not cut the 5/8-inch plywood. Spring for pressure treated exterior plywood so you won't have to worry with paint, rot, or the glue dissolving. As you bolt the bed down, use an eyebolt in the middle of the front edge instead of a bolt to provide a central tiedown point. Later, after the pressure treating chemicals have dried out, you can paint the top of the bed with a porch and deck enamel if you want. Stir in a bit of fine sand for a non-skid surface.
    A second piece of angle iron under the back of the trailer frame provides a good outboard position for rear tiedown points, as well as more substantial mounts for the lights. Watch your shins. You have been warned!
    Next thing you'll need is wheel chocks. The tubular steel kind can be had in widths suitable for TW tires. They can be fastened firectly to the wooden bed using fender washers to prevent pulling through the bed. If you buy as removable kit like http://www.ebay.com/itm/6-5-MOTORCYC...sories&vxp=mtr Be sure to provide adequate backing plates under the bed. Tubular chocks are significantly lighter than other options, work well, and not really a good place to scrimp.
    Next, you'll need ramps to load and unload your bikes. A simple ramp kit such as http://www.oreillyauto.com/site/c/de...0771&ppt=C0373 is another place scrimping can cause serious regrets. The ramp tops have holes to take bolts that then slip into holes drilled in the bed to prevent the ramps from slipping. Cheap insurance. Bike in 1st at idle pulling itself up one ramp, you trotting along beside up the other. Takes a bit of confidence, but easiest way ever to load a TW. Unload by rolling the bike down one ramp while walking on the other, using the front brake to control speed. Easy-peazy. Add a couple 2x4 to the bottom of each ramp, and they fit in the stake pockets for easy storage. Be sure to use clevis pins to keep them from bouncing out.
    Don't buy cheap tiedown straps. Scrimping on straps is probably the #1 cause of motorcycles falling off trailers. Many straps sold today have the hooks cut too short. Hooks on right good, hooks on left bad:
    Avoid cam buckle straps--they have a bad habit of slipping and dumping your bike. Ratchets are the way to go. Best straps I've ever had--good hooks with safeties, ratchets with big handles, built-in soft ties:
    Here you can see the rear angle iron in use:
    Note how one of the ramps fits across the back of the trailer.
    Note how the angle iron is used to position outboard tiedown points front and rear.
    You can see the sideboards and a second ramp being used as a headboard.
    The Harbor Freight trailer kit is all you need for two dualsport bikes. Set up as described it will do double duty as a utility/stakeside, too.
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    I too have solid bed for all sorts of duty. When I bought my Van got the trailer with it.
    NOTE: Many friends without garages spend the relatively big money for a box trailer and use it as the toy garage too.
    Before you leap at least to a general craigslist search people are in and out of that stuff almost daily
    Hailey, Idaho
    44
    thanks, great, got it, I'm good.
    Senior Member Jay64's Avatar
    Richland, Oragun
    124
    qwerty
    Have you thot about collecting your more informative posts into a I-book? Damn! But you and they are good. This comment of yours should at least be copied to http://tw200.wiki-site.com .
    No this isn't a man-crush; just an appreciative acknowledgement of your willingness to share your understanding about a myriad of matters pertaining to our poco burro.
    The greatest trick that Jay64 ever pulled was convincing the world he did exist.
    Senior Member 805gregg's Avatar
    Oct 2010
    572
    Or you could make your own, like I did. I would stay away from HF junk.
    Senior Member rm_hm's Avatar
    1,619
    Northern Tool Has a bunch of trailers & most have free shipping. http://www.northernt...-parts+trailers
    I bought the one below from them and have been very happy with it.. The tires are bigger then the real cheap trailers and rated for as fast as my Ranger can go. I added a tongue jack & spare tire to the front , then two drop down stabilizers to the back so I could load it without the trailer being hooked up to the tow car.
    Another idea is to search for a old small single axle horse or travel trailer. Then Strip it and re-purpose it.
    I sometimes still use my motorcycle hitch carrier for my tw & rv90. Similar setup below.
    Works great if you have a hitch rated for the weight and good suspension.
    If I had had 2k laying around I would have bought one of these instead...
    Senior Member TuggerHiller's Avatar
    May 2011
    Long Island, NY
    362
    +1 an old small pop-up camper might have a decent base to work with
    2007 T'dub
    Cyclerack/Dual Northern Tool Boxes/AVG Miglia Helmet/Infamous Tubes/Fanny Pack/ATV Tank bag
    Quote Originally Posted by 805gregg View Post
    Who do you trust, some mechanical engineer that happens to be Chinese or some self-proclaimed judgemental internet "expert"?
    I worked for a trailer manufacturer for a few years and a big part of my job was doing failure analysis. The vast majority of failures were caused by neglect and mis-use, not by shoddy engineering or manufacturing. What I've seen with home-builders has been extreme over-engineering resulting in longevity at the price of higher initial cost and lower operating efficiency. A 3500 pound capacity axle and springs under a single TW can spend as much time airborne as in contact with a bumpy road, leading to a jacknife in an emergency stop situation. Even 2 TWs, fuel, and gear barely adequately load a 3500 pound axle and springs. Never thought of under-load problems, didja? Of course, homemade isn't always expensive--significant scavenging can be done to find usable components at a low price, which provides parts and materials of unknown stress damage. Even then, add in the cost of machining, welding, and painting, or machining, welding, and painting equipment and supplies, and the cost can skyrocket. That said, a complete good used trailer that actually meets the user's needs will often be the most cost effective option.
    For the purpose of towing two dualsport bikes and gear up to a total of 800 pounds or so, the Harbor Freight trailer kit is about ideal when the simple mods I outlined are incorporated.
    Senior Member jbfla's Avatar
    FL. GA, NC
    2,406
    ... some self-proclaimed judgemental internet "expert"?...
    Would that be you?
    I, too, prefer a small utility trailer that can have many other uses, as shown in Qwerty's photo.
    This 4' x 8' professionally built trailer is light, strong, well-balanced, and can be easily towed behind a small 4 cylinder car.
    jb
  1. Do you have any paint recommendations?
    Last Post: 01-29-2013, 04:53 AM
  2. Parts Ordering Recommendations
    By Gator in forum General Discussion
    Last Post: 09-12-2012, 03:33 PM
  3. Recommendations on a naked bike
    By RodneyBR in forum Off-Topic
    Last Post: 08-20-2011, 01:58 AM
  4. I Need Some Recommendations
    By assquatch20 in forum General Discussion
    Last Post: 04-26-2011, 08:06 AM
  5. Any recommendations for Flagstaff area?
    By the-wild-man in forum Trails, Off-road, and Adventure Riding
    Last Post: 10-01-2010, 04:18 PM
homemade single axle camper trailers
small trailer axles
