1987 tw200
Results 1 to 5 of 5
Thread: 1987 tw200
    Junior Member big jim's Avatar
    Nov 2011
    1
    I am having a problem when riding my 1987 tw200, when first started up it seems fine but after riding a few minutes, sometimes longer than others it starts bucking like a bull. Acts a little like not getting gas but believe it is electrical. Carburator has been cleaned and tank is clean. Am looking to replace the black box since I understand that the electronic ignition on early models was sometimes a problem. Does anyone have a used black box (computer) to sell.
    Member Jon H's Avatar
    Oct 2011
    Aurora, CO
    85
    +1 here. Its kinda hard to warm up to the $250 needed to get a new one online.
    1987 TW200
    2000 Yamaha XT350
    2005 Yamaha Majesty
    2009 Honda Ruckus
    7,001
    Maybe some clever soul can get one of these CDI to work on a TW. The price is sure right but I wonder about the quality.
    First entry on the page is "painless universal wiring harness or TEST harness". Make me chuckle!
    http://www.buyatvsonline.com/electri...cts_sort_order
    Nov 2010
    Frostbite Falls Ill
    2,719
    Quote Originally Posted by big jim View Post
    Big Jim, You probably have a restriction in the gas flow. If you have an inline filter, change it. If not clean the carb and check all fuel lines for restriction.
    Replace the float bowl valve and seat. Check float bowl adjustment.
    If you get some gas but not enough, it will do exactly as you describe. It will run well until the float bowl gets low. The it gets erratic or dies.
    Some years ago when I discovered that alchohol in fuel can make some plastic deform, I discovered my plastic in line filter doing as you describe.
    Shut off for a minute and enough gas got through to do it again. very frustrating until I found it.
    Phelonius
    Junior Member TommyBoy's Avatar
    Nov 2011
    Knoxville
    24
    I recently had a similar symptom when I took my recently purchased 1988 TW for a ride. Did a few test rides and it acted fine, but the first time I went on a long ride it it acted the same as you described. Got the bike home and put the product called Sea Foam in the tank with a fresh fill of 93. Ran the mix through and after 800 miles the problem has not returned.
  1. 1987 TW200 CDI box
    By TheRedRider in forum Technical Help
    Last Post: 05-27-2013, 02:35 PM
  2. 1987 TW200
    By wsb1206 in forum Technical Help
    Last Post: 10-26-2012, 05:12 PM
  3. FS: 1987 TW200
    By stinkycheezmonky in forum TW200 Classifieds
    Last Post: 05-24-2011, 03:22 PM
  4. 1987 TW200 CDI
    By wiley in forum TW200 Classifieds
    Last Post: 03-10-2011, 09:22 PM
  5. FS: 1987 TW200 in MD
    Last Post: 11-01-2010, 04:37 PM
1987 tw 200
1987 tw 200 spec
1987 tw200
1987 tw200 review
1987 yamaha trailway 200
1987 yamaha trailway 200 specs
1987 yamaha tw 200 specs
1987 yamaha tw200 backfires and dies
1987 yamaha tw200 review
1987 yamaha tw200 specs
1987 yamaha tw200 value
yamaha tw 200 1987
