forks
Results 1 to 10 of 15
Like Tree36Likes
Thread: forks
    Jan 2017
    Southern Nevada
    1,077
    forks
    I first checked the technical section and then the performance section, using advanced search and did not find an answer.
    On a washboard road, yesterday, the front suspension seemed a bit harsh.
    Reminded me of my first new bike, a 1967 Honda CB160 on which I broke 5 headlight mounting rings from jumping it in the woods near McGuire AFB.
    Now, I really not not expect it to have suspension for jumping...it's just that the TW fork action reminded me of it.
    On my early seventies Yamaha enduros, changing fluid was easy, with drain screws at the bottom of the forks.
    Not as easy on the TW.
    So, rather than experimenting with different viscosity, what has already been tried?
    I am not doing wheelies and I am not planning on jumping it...other than front may have been a few inches off the ground over whoop-de-doos on the trail, after Gass Peak Road officially ended.
    Ken
    Ken is offline
    Senior Member Ken's Avatar
    Aug 2016
    Houston, Texas
    1,957
    These do have the drain screw on the lower fork leg. A Phillips (probably a JIS) screw. The top cap on the TW is easy to put on or off. Others on here have recommended 130mm fluid height. I have only used 10 weight so I can't give recommendations there. Be sure and check the manual for procedures.
    Pleasanton, CA
    5,777
    Quote Originally Posted by Ken View Post
    Only model years 1987-2000 have the drain screws on the lower fork legs. Yamaha deleted these drain screws beginning with model year 2001.
    Ken
    Ken is offline
    Aug 2016
    Houston, Texas
    1,957
    Thanks for the update. A dumb move on Yamaha's part.
    littletommy likes this.
    Dec 2015
    San Diego
    1,865
    Did you see this under Lizrdbrth tech tips in the tech stickies? See post #10 and post #13. The zip tie drill. I haven't messed with my forks yet but probably will before Moab.
    https://tw200forum.com/forum/technica...-changing.html
    19,019
    SportsterDoc, were you bottoming out the ~6 inches of suspension travel, or was the "harshness" reported due to insufficient travel being used to soften the washboard impacts? Two opposite causes could be at play for you; either too firm, or too soft.
    Ken likes this.
    Jan 2017
    Southern Nevada
    1,077
    Fred, that is a very good question. At the time, it seemed harsh, undampening, that the forks were not moving enough.
    However, after starting this thread (i sometimes do things backwards), I went out to the garage and pushed on the handlebars.
    They seemed soft. I am 182, but with gear, probably 200#
    So, maybe they were bottoming, although they did not have the slamming feel that I've felt in stock forks of the enduros of yesteryear.
    There is another factor to this equation. Either I am not as good a rider as I remember being or age is simply making me much more cautious.
    Due to the cobble on the road, I was only doing 15-20 MPH. Had I been doing perhaps 30, maybe I would have felt the washboard less.
    North and east of Corn Creek Springs, I am finding a lot of sizeable loose rock.
    When speed was attempted, my front tire would plow, instead of going where I wanted.
    This is not the type of riding as found around Randsburg, where slaloming around creosote bushes at 60 MPH was comfortable, i.e, relatively soft terrain, but not deep sand.
    Ken likes this.
    Jan 2017
    Southern Nevada
    1,077
    Quote Originally Posted by Tweaker View Post
    Thanks, Tweaker.
    With fork boots, I am not seeing fork travel.
    All three of my early seventies Yamaha enduros ran heavier oil, a tad more oil level (son't ask me to remember what a tad was) with stock orifices.
    Tweaker and Ken like this.
    Jan 2017
    Southern Nevada
    1,077
    Annoying, but probably saved Yamaha a few Yen, which kept the purchase price more affordable.
    Ken likes this.
    Dec 2015
    San Diego
    1,865
    I like his methodical set up first set the sag for your weight with proper spacer, then add oil in increments, then change weight if needed.
    littletommy, socalnative and Ken like this.
  1. Forks?
    By mikejana in forum Performance and Customization
    Last Post: 02-14-2017, 04:01 PM
  2. Forks
    By will in forum Technical Help
    Last Post: 09-08-2015, 10:51 AM
  3. I see some of you are playing with the forks.
    By ZDR1 in forum Technical Help
    Last Post: 10-19-2014, 05:39 PM
  4. yz80 forks... again
    By wrstlr119 in forum Performance and Customization
    Last Post: 05-07-2013, 02:38 PM
  5. Replies: 5
    Last Post: 05-03-2012, 12:23 PM
