Bridgestone TW204 & 203 Tire advice
Results 1 to 10 of 14
Like Tree50Likes
Thread: Bridgestone TW204 & 203 Tire advice
    Junior Member frenchy51's Avatar
    Mar 2017
    7
    I'm thinking of replacing my original knobbies on my '07 TW200 with these Bridgestones. I mainly ride on gravel and dirt fire roads and about 30% street use. Good choice or should I stick with the Knobs? Thanks
    Ken likes this.
    Jul 2012
    Wet-ern Washington
    1,415
    Although those tires will work fine, I think a new stock rear and a Shinko 241 or Pirelli MT 43 trials type for the front would be the best for what you describe.
    - Leisure Time Larry -
    Hailey, ID
    3,405
    I'm with Larry. Stick with the stock rear and put a Shinko 241 on the front....they will do fine on the pavement and be much better in the dirt/gravel.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Mar 2015
    Ynys Môn
    4,641
    I have one bike with knobs on – and one with the 203/204 combination
    The 203/204 tread pattern is designed to put as much rubber on the road as possible, while still allowing for the occasional off road foray. In gravel, they tend to drift, and the same goes for dry dirt, where the surface rubber has no grip at all (eg 90% of the 203/204 tires profile)
    Where they do excel is on tarmac, where the rubber can get a grip and do what it’s best at. So for 70% road use, they are excellent. In such circumstances they are more capable of sustained high speed running, producing less drag for more grip – off-road the opposite is true
    We have a member here (bananachunks) who swears by them, but again, the on-road/off-road suits his rides.
    The TW34 (knobbly) rear is widely acknowledged as having as much grip as the smoother version, but over a wider set of circumstances, both on and off road. Sure, it will still drift in the loose stuff, but offers more grip when you need it. The TW31 (front stock knobbly) however, is lethal at best, and is usually replaced as soon as possible (followed by the front brake and clutch levers) – affectionately referred to as the “death wing” - you get the picture
    There are many options for a knobbly front tire, the Shinko 241 is the current favourite, but it’s a matter of personal choice.
    What I can’t personally recommend is a mix of smooth and knobbly – tried it – expensive mistake (handling issues)
    Your buck – your choice – but for the riding you do, perhaps not a good idea …….
    - Hidden Content
    Mar 2017
    7
    Thanks all-Decided to keep the original rear and replace the front with the Shinko 241. Love this forum!
    jtstdub, Ken, fishguy and 3 others like this.
    Hailey, ID
    3,405
    You will be very happy with the Shinko 241, both on and off road. Around 18 psi on road, maybe higher for long stretches at full speed, around 12 to 14 in the dirt. I've had mine up to 60 mph at those low pressures for 5 miles or so, but beyond that I would air up...mileage is distinctly better at 18 psi and above, front and rear.
    Ken and littletommy like this.
    Rocky
    2018 TW200
    2014 BMW R1200GS LC
    Senior Member cowboyjeff's Avatar
    Nov 2013
    West Jordan, Utah
    207
    Frenchy, I have the Shrinko 241's on the front of both my Tw's, I replaced the originals way before they needed it.
    I can tell you this it was the one huge difference right off the bat. I love them.
    I am thinking about replacing the rears only because they are over 25 Years old, they steal have a ton of tread and I have never had a flat tire, and I hardy ever have to add air.
    I just wonder if they might be getting a little brittle. I hate to wast $300 bucks if there will be no noticeable difference.
    Biking through Africa with Cornelis
    17,594
    At 25 years old, they are dangerous!! Replace them ASAP!!
    Quote Originally Posted by cowboyjeff View Post
    1st John 1:9
    John 3:16
    John 3:17
    Feb 2013
    Missoula, MT
    908
    I feel your pain but you gotta replace the 25 year old rear tire. You WILL notice a difference! Have we EVER lied to you?
    Mar 2015
    Northville, MI
    779
    Replacing my 10yo rear with new was noticeable! A ittle better off road and a lot quieter on road.
    cowboyjeff, littletommy and Ken like this.
    2002 TW200 "The Punisher"
    1998 DR350r
    1996 KDX 200
  1. Replies: 14
    Last Post: 06-06-2016, 12:00 AM
  2. Bridgestone Trail Wing 203/204 tires near new.
    By 82fb in forum TW200 Classifieds
    Last Post: 03-05-2016, 06:46 PM
  3. Replies: 2
    Last Post: 07-06-2013, 12:59 AM
  4. Have you ever used the TW204/203's offroad?
    By mikesova in forum General Discussion
    Last Post: 03-08-2013, 08:17 PM
  5. New Unused Bridgestone TW203 & TW204
    By papa wheelie in forum TW200 Classifieds
    Last Post: 09-15-2012, 09:45 AM
