Kolpin Fuel Pack Jr. Mounting Options
Results 1 to 2 of 2
    Senior Member Kankujoe's Avatar
    Missouri, West Central
    157
    If I go with a larger gas tank I'd like to use a larger metal tank. I really like using a magnetic tank bag.
    Awhile back I bought a Kolpin Fuel Pack Jr. without any mounting brackets. I like the ability to use it on both my TW & my Versys when I need more range.
    On my TW I'm not sure which way to mount it. I have both the front & rear CycleRacks.com racks so I have several possible mounting spots but I'm not sure which way I want to go. When I have used it I've lashed it flat on top of my OGIO tailpack using a buggie net. This works okay but I think I'd like a more secure mount.
    I don't expect to carry it full of fuel most of the time, only when I know I'll be outback for extended distances.
    I have found 2 different Kolpin mounting options: 1) Pack Mount ~$17 and 2) Bracket Mount ~$40... Trying to decide which way to go...
    Where have you mounted yours?
    What mount did you use?
    Can these mounts be modified to hold two fuel packs?
    KJ
    2008 Yamaha TW200
    2011 Kawasaki Versys
    2012 Suzuki V-Strom-ADV
    2013 Honda CRF250L
    157
    I decided to use the "Bracket Mount," on my TW attached it to the rear of the CycleRacks rack. I had to modify the mount slightly, the U-bolts only fit on one cross member of the rear rack which allowed the fuel pack to rotate under jarring forces on gravel & dirt. I added a "J-bolt" which hooked to the upward bend of the rear rack. This elimiated the rotation & the fuel pack stays put.
    KJ
    2008 Yamaha TW200
    2013 Honda CRF250L
  1. Mounting Kolpin or similar tank horizontly
    By bikerjosh in forum Performance and Customization
    Last Post: 11-26-2012, 09:42 PM
  2. Kolpin Gas Pack
    By retmotor in forum General Discussion
    Last Post: 09-22-2012, 05:45 PM
  3. Kolpin gas can L-Bracket to Cyclerack mounting tips/tricks?
    By n8bone in forum Performance and Customization
    Last Post: 08-12-2012, 09:27 AM
  4. Brand new Kolpin Fuel pack/bracket kit
    By mga60tw in forum TW200 Classifieds
    Last Post: 01-25-2011, 05:44 PM
  5. FS: Kolpin Fuel Pack Jr. with pack bracket
    By n8bone in forum TW200 Classifieds
    Last Post: 08-22-2010, 11:44 AM
gas can mounting options
kolpin mounting options forum
kolpin puel pack mount options
tw200 forum kolpin fuel pack mount
