Would it hurt
Results 1 to 5 of 5
Thread: Would it hurt
    Junior Member frogman215@hotmail.com's Avatar
    Feb 2012
    10
    If I were to change the sprocket setup to a 15/50 could I still run my tdub wide open without damaging the motor
    Senior Member srs713's Avatar
    Smyrna, GA, USA
    1,417
    Quote Originally Posted by 20TW01 View Post
    That is my setup. 15/50. I ride WFO on the freeway a lot.
    Watch the oil level, and realize it will get lousy gas mileage running that hard.
    Stephen S.
    '07 TW200:
    No problem running WOT, and srs is right about the oil and fuel consumption.
    Nov 2010
    Frostbite Falls Ill
    2,719
    If your body weight is more than 200 pounds, you might not get any higher speed except on down hills
    Phelonius
    Since I've had Tdub my body weight has varied between 170 and 280 pounds. Small changes in sprocket ratio won't make any change in maximum speed with a stock engine. Though the TW has a nice, wide powerband, it simply does not make enough power to pull redline in most cases with stock sprockets. Changing the sprocket ratio a little simply changes engine rpm without changing the amount of torque the engine puts to the ground, so speed doesn't change.
