Was this the Death Wing Dance?
Page 1 of 4 123 ... LastLast
Results 1 to 10 of 34
Like Tree116Likes
Thread: Was this the Death Wing Dance?
    Member revtbob's Avatar
    Jun 2016
    37
    This afternoon I headed down an unknown trail, which was a mixture of gravel and clay. Recent heavy rains had left puddles but nothing serious.
    The trail suddenly turned and descended rapidly and I spied a 90° turn coming up. I peripherally noticed deep wet loose gravel so I applied the rear brakes lightly and The front brakes gently— or so I thought. Suddenly the front tire went sideways and down we went. I was barely going but a walking speed, so I wasn't hurt a bit when I bit the dirt.
    After hitting the kill switch, I heaved up the bike. I felt like a dumbass.
    I have the stock tire on the bike, and I was wondering if this was partially the result of the tires performance?
    Nov 2010
    Frostbite Falls Ill
    2,719
    You just need more practice riding in crud, especially up and down crud.
    Phelonius
    Frosty Hollow
    13,174
    Quote Originally Posted by revtbob View Post
    What was your tire pressure? Lower tire pressure in any tire including the stock front tire well help in that kind of situation. Of course, that is not to say the stock tire wasn't at fault, because it doesn't do that well off road, but the lower pressure will help. There are some people who have ridden for just a short bit and have had a spill and got hurt badly, but others have ridden with that tire it's entire lifespan and nothing ever happened so a lot of it is the rider, not the tire.
    Just the same, and for peace of mind, your best bet would be to change that tire to a 241 or 244, or something better so that doesn't happen again.
    Biking through Africa with Cornelis
    17,595
    Typical deathwing.
    1st John 1:9
    John 3:16
    John 3:17
    May 2013
    Groton, NY
    2,663
    Stock tire is OK unless your on gravel, mud, sand, dirt, grass, but other than that, it's OK.
    2013 Yamaha TW200
    1996 Yamaha TW200
    1995 Kawasaki KLR650
    Senior Member Elvesus's Avatar
    Jun 2015
    Nanaimo BC
    311
    I find the Shinko 241 much more forgiving than the stock front tire on loose ground. It maintains better traction in situations where the stocker bounces around or might wash out. It has probably saved me from going down a time or two when I've been using less than perfect off-road riding technique.
    John in Nanaimo
    2013 TW200 - with Shinko 241 front tire, Rox 2" anti-vibe risers, Polisport Touquet handguards, homemade wind deflector, Manracks utility rack
    Jun 2016
    37
    Is the 4.0x18 the Shinko 241 size to get?
    admiral and littletommy like this.
    Feb 2015
    Maple Ridge, BC, Canada
    1,599
    Quote Originally Posted by scotti158 View Post
    You forgot roots, rock gardens, loom and leaves.
    Mar 2011
    NJ Shore / Pine Barrens
    3,891
    The issue "the deathwing" has is... that when it lets go, it let's go fast and trying to save it is usually fruitless and impossible as your on your side in an instant... Learn and remember its limits and you'll slide out less. Better tires generally allow you to recover before eating dirt whereas with the deathwing there is no "in between", your up... then your down. That's been my experience anyway. It's ok on dry asphalt though, I've pushed it harder then I should have and been ok. But like scotti says with grass, gravel, sand, etc... watch what youre doing and learn it's limits. That's your job as the rider, to learn not only your bikes limits, but your own too. I rode a deathwing for a long time, didn't want to toss a new tire, but now having experienced much better tires it's just not worth using that tire, the cost of a good one is next to nothing compared to what you could damage in just one fall.
    admiral, ejfranz, Tweaker and 5 others like this.
    Husqvarna TE300i Fuel Injected 2-Stroke 2019
    Yamaha XT225 - 1999 Serow
    Yamaha TW200Z - 2010
    Yamaha BW200 Electric Start! - 1986
    Yamaha TTR225R - 2003
    Husqvarna 701 Enduro - 2017
    Kawasaki Prairie 650 - 2002
    Jun 2016
    37
    Quote Originally Posted by JerseyJeeper View Post
    You described it exactly: " when it lets go, it lets go fast." That's how it happened to me. Even though I was barely going but a walking speed, the front tire slid out like it was on ice instead of wet, loose gravel. Scary.
    As soon as someone can confirm the correct size I'm ordering one!
    It is 4.0x18" right?
  1. You Folks Like to Dance?
    By Fred in forum Off-Topic
    Last Post: 06-28-2016, 07:43 PM
  2. The "Death Wing" - and the end of an era ..........
    By Purple in forum General Discussion
    Last Post: 06-10-2015, 10:13 AM
  3. Music Video - TW200 Dance
    By docjekyll2002 in forum General Discussion
    Last Post: 08-13-2014, 05:26 PM
  4. Still doing the Dance??
    By abartlett355 in forum Technical Help
    Last Post: 04-02-2013, 06:00 AM
  5. JerryT on his wing
    By longroof in forum Trails, Off-road, and Adventure Riding
    Last Post: 08-05-2010, 02:06 PM
