question about my chain
Results 1 to 10 of 10
    Member brent morley's Avatar
    Feb 2012
    Dayton Tenn.
    57
    Just asking anyone if they know. If i go with a 14 / 47 sprocket will my chain still be 122 links or will i need a different size?
    I got granny gear haha...
    Ephrata, WA
    1,125
    122 should work.
    1990 TW200
    Feb 2012
    Dayton Tenn.
    57
    yhea im trying to get a little more speed on the top end. about 5 more miles a hour i think. do you know where's the best place to get a 14/ 47 sprocket and a did o ring chain at?
    Feb 2012
    Dayton Tenn.
    57
    im having trouble finding a one stop shop for that and a gasket. Can you help
    Jun 2011
    Dothan, AL
    1,715
    Stadium Yamaha
    Your not getting 5 mph though, unless it's down hill with a tail wind.
    2005 TW200 (SOLD)
    2013 DR650
    Tennessee
    1,300
    Make sure to replace the retainers on each sprocket, and the bolts for them as well. While you've got it apart, do your two countershaft seals and maybe even the shifter seal, as you might not be back in there awhile. You could maybe spring for a spare gasket as well.
    People will argue all day about lubes and sealants, but I like a practically invisible coating of Permatex RTV sealer on the cover side, and a liberal amount of vaseline on the inner side of the gasket. A little oil smear first wouldn't hurt, obviously.
    Ephrata, WA
    1,125
    Quote Originally Posted by brent morley View Post
    Try oemcycle.com
    I bought my stock gaskets, JT sprockets, and chain from them. They consistently have the lowest prices as well.
    1990 TW200
    Mar 2011
    Gobles, michigan
    1,824
    120 link is perfect for a new replacement on that combo............ Puts your adjustment scale at maybe 2ish.. OMM.
    Senior Member icpchad's Avatar
    Mar 2012
    Yakima, Washington
    152
    It will definitely work. The chain adjustment will take up the slack. (just barely)
    Like others have said: It won't increase your top speed, but it will lower your rpms.
    - Chad
    Ride Along With Me On YouTube: Hidden Content
    Sep 2011
    Southcoast MAsshole
    2,661
    i bought a chain and sprocket kit from these guys...
    http://myworld.ebay.com/lytleracinggroup/
    not the gearing you want but they have others i think...
    http://www.ebay.com/itm/DID-O-RING-C...#ht_3921wt_908
    for oem parts i use these guys...
    http://www.ronayers.com/
    found these guys to be more expensive...
    http://www.bikebandit.com/
  1. The $5 chain
    By disenfranchised in forum General Discussion
    Last Post: 08-02-2012, 09:22 AM
  2. Chain
    Last Post: 07-25-2012, 09:32 PM
  3. Chain and sprocket question
    By Boarder255 in forum Technical Help
    Last Post: 06-29-2011, 07:19 PM
  4. chain question
    By muliefever in forum Technical Help
    Last Post: 04-08-2011, 12:32 PM
  5. help chain
    By Logan in forum General Discussion
    Last Post: 01-25-2011, 09:18 AM
