Headlight
Results 1 to 10 of 10
Thread: Headlight
    Member chasejamy's Avatar
    Sep 2010
    Calif.
    59
    Is there a way to put switch, so I can turned off the head light? I read there is a way for older bikes,
    but mine is a 2008. I have a rack on the front for a little ice chest, head light has to much heat.
    I have a rack, on the back, but wanted to mount it on the front. Thanks Mike
    Junior Member IdahoSmitty's Avatar
    Aug 2011
    Boise, ID
    28
    https://tw200forum.com/index.php?/top...__1#entry28869
    Sorry, I didn't see that you read about older bikes
    Senior Member jpuck's Avatar
    Feb 2012
    dayton mt. tn.
    110
    i have read that with light off it will over charge the battery.
    Senior Member rm_hm's Avatar
    1,619
    I added a handlebar switch wired to the headlight low beam. Mainly so if I have starting problems I can crank without the headlight being on.
    Idling with the headlight off I start getting acid out of my flooded battery overflow tube after several minutes. (first time I tried this the bike was new had 150miles on it)
    On another note does anyone here replace their headlight bulb before it burns out?
    i guess if mine burns out I can use high beam and lower the adjuster till I get home.
    My riding is 99.7% during daylight
    Desert, SoCal
    7,369
    Quote Originally Posted by Rich View Post
    Carry a spare. Wrap one in bubblewrap and stash it in the little rectangular chingas in the rear fender, behind the tail light.
    Real pain to get to, but you can stash spares of every bulb on the bike in there.
    Senior Member frog13's Avatar
    Jun 2011
    SW, Ohio
    2,518
    Quote Originally Posted by jpuck View Post
    Wouldn't think so unless the regulator is bad?.
    Jun 2011
    SW, Ohio
    2,518
    Like lizrdbrth said, carry a spare. If you don't care for his storing suggestion...still bubble wrap it and place it in your bag?.Good to have a spare.....anything!.
    Quote Originally Posted by frog13 View Post
    There is no regulator. TWs have a "balanced" system. The alternator is designed to put out just enough more than the lights use to keep the battery charged.
    EDIT: Measure the resistance through the headlight. Wire a resistor with the same resistance parallel to the headlight from a double throw switch. Switch up, resistor instead of headlight. Switch middle, infinite load for problem starts. Switch down, headlight instead of resistor.
    Senior Member gfletcb's Avatar
    Jun 2011
    181
    the other side of the resistor is grouned? on my atv the headlight is controlled by the ignition, wondering if theres way to incorporate something like that to make it work rather than hacking and splicing a wire harness.
    Headlight is a simple DC circuit. A double throw switch and resistor (yes, resistor output goes to ground) provides an optional path for the electricity to flow. Take your bulb to Radio Shack. They'll be able to set you up with everything you need, including wire terminals to build your own plug-n-play wiring harness adapter, if that is what you want.
  1. round headlight / dual headlight
    By fredzaha in forum Performance and Customization
    Last Post: 05-04-2015, 01:32 AM
  2. headlight help
    By PalmStateCrawler in forum Technical Help
    Last Post: 02-19-2014, 04:40 AM
  3. Think this headlight would work?
    By Deldog in forum Technical Help
    Last Post: 05-16-2013, 04:38 PM
  4. New Headlight !
    By FnMag in forum Performance and Customization
    Last Post: 12-25-2012, 07:50 AM
  5. Any ideas where to get a headlight bracket for a bottom mounted headlight
    By Lauro13 in forum Performance and Customization
    Last Post: 08-22-2012, 10:52 PM
tw200 headlight off
