Stuff it sort of twice
Results 1 to 10 of 10
    Senior Member Stromper's Avatar
    Oct 2011
    Eastern Connecticut
    443
    two times today I think the front wheel first got loose.
    Perhaps I over corrected
    Then it bit and the bike turned real hard
    Next thing I know I am face planted in a mud puddle.
    Unusual in my experience as usually on other bikes it just washes out and you low side
    Anybody else ?
    Senior Member bcscammell's Avatar
    Oct 2011
    264
    Quote Originally Posted by Stromper View Post
    Anybody else ?
    I've experienced exactly the same thing. Too much torque at the rear raises the front with great ease, when it comes back to earth you're done. The only solution is to lean out your carb by plugging the main jet and removing the needle all together. Replace the rear sprocket with an after market 10 tooth. This should reduce
    the massive wheel lifting torque to a managable level and you should still be able to cruise at 95 mph uphill.
    Jun 2011
    Dothan, AL
    1,715
    Gravity, it's a real bitch!
    2005 TW200 (SOLD)
    2013 DR650
    Oct 2011
    Eastern Connecticut
    443
    Losing the snarky
    You would say that the size and traction of the rear tire over
    power the front.
    Where as a conventional dirt bike the rear would spin out first and create a slide or low side
    The big rear here bites in and start the front slipping and/or lock up
    Down you go.
    So put more weight over the front?
    Hold it down the front and lighten the rear.
    Any thoughts discuss ?
    Oct 2011
    264
    Losing the snarky
    Sorry, it was the first thing that came to mind. Seriously though, I have actually pondered this and have decided in my case that it happens because of the way I ride. I tend to stay a little rearward on the seat even when cornering. Maybe because I'm a little long for the bike or because I saw no need to crowd the tank as I didn't want the back end to slide out, even though it would put more weight on the front and possibly keep it from getting loose.
    Senior Member JagLite's Avatar
    Aug 2010
    Anchorage, Alaska
    551
    What front tire are you using?
    That makes a huge difference.
    James
    ______________________
    Attitude =
    The difference between
    Ordeal and Adventure
    Senior Member xdac's Avatar
    Mar 2011
    Gilbert AZ
    1,076
    Throttle out of it...body position...lean with your body not the bike...get a decent front tire....you dont loose points for putting your foot down either
    Oct 2011
    Eastern Connecticut
    443
    Bike is 08 stock including tires
    My prattle is that I think I still have my old dirt bike instincts and they let me down
    or the TW fat tires etc. react differently
    Mar 2012
    Boonville, No.-Calif.
    1,357
    Your dirt bike instincts probably played a role. Most dirt bike riders are going like hell through these slippery spots, and when I've tried to keep up with them, being a rider who has always preferred the low & slow, I end up sliding all over the place if I’m not careful. I tend to ride forward, close to the tank, but everyone has their own style. Jaglite & Xdac have a good point too, many members say ditch the stock tires, they are poor performers. This is something I intend to do on my own TW. Get back on that horse! m.
    1997 TW with some modsHidden Content Pike'n the Boont region since 1989!
    Have a Bahl Dee! Hidden Content
    Senior Member Gerry's Avatar
    Paradise, Calif.
    3,514
    Think you will hear this from more than a few folks; the front tire is pretty marginal in the dirt. I ditched my after a little over 1000 miles. Mine would twitch and slide and seemed to have a mind of it's own. I found myself with a mouth full of dirt on a couple of occasions, and I was tearing it up at about 15 mph. Consider a new tire, I suspect you will be given so good advice. Gerry
    Take care my Friend.........
  1. TTR stuff for Tw's
    By lizrdbrth in forum Performance and Customization
    Last Post: 07-31-2017, 02:29 PM
  2. Starts, Then Won't Stay Running (Sort Of)
    By Oldad in forum Technical Help
    Last Post: 09-27-2016, 02:36 PM
  3. Newbie here (sort 0f)
    By jrdavis in forum General Discussion
    Last Post: 07-18-2011, 07:39 PM
  4. Hello Newbie here sort of
    By RisingSun in forum General Discussion
    Last Post: 06-10-2011, 05:53 PM
  5. Still Lurking-Sort of-I Guess
    By TW2007 in forum Off-Topic
    Last Post: 11-16-2010, 07:33 AM
